thefabricator03 wrote: What program do you use to do your schematic drawings?
Where does this code go? Also, are these two lines of code specific to one zone? ie: will I need eight sections like this, one for each zone?rodw wrote: I generally would do it like this:
Code:net zone0 <= ddraft4x2.0.trigger-0 net zone0 => hm2_7i76e.0.7i76.0.0.output-00
I am sure this will make more sense the once I grasp the first part.rodw wrote: So if you wish to change the zone boundaries you can edit ddraft4x2.hal file to change them
rodw wrote: Yes, you need 8 pins like that using the pin names from the component, like I created. zone0,zone1, .... zone7
