Prox sensors for plasma table - Advice needed
- txtrone
- Thank you received: 106
21 Dec 2020 21:50 #192727
by txtrone
Prox sensors for plasma table - Advice needed was created by txtrone
Which/what type of proximity sensors have worked well for home and limit switches? I am wiring up a 5' x 10' plasma table, using a Mesa 7i76e, and would like to use some decent proximity sensors.
Also, how exactly do the home and limit sensors/switches connect to the 7i76e?
Thx
Thx
- thefabricator03
- Visitor
21 Dec 2020 22:00 #192731
by thefabricator03
Replied by thefabricator03 on topic Prox sensors for plasma table - Advice needed
I cannot recommend the prox sensors as I use industrial limit switches but I have attached my wiring diagram I made for wiring my 7i76e which shows how I wired up mine.
- txtrone
21 Dec 2020 22:17 #192735
by txtrone
Replied by txtrone on topic Prox sensors for plasma table - Advice needed
Thanks! Which limit switches did you go with?
- thefabricator03
- Visitor
21 Dec 2020 22:21 - 21 Dec 2020 22:22 #192736
by thefabricator03
I am using these Telsa brand switches I brought locally.
www.teslacomponents.com.au/products/elec...ssories/limit-switch
Last edit: 21 Dec 2020 22:22 by thefabricator03.
- Thank you received: 7488
21 Dec 2020 22:32 #192737
Replied by tommylight on topic Prox sensors for plasma table - Advice needed
I used prox on the last two and will use on the two current builds, cheap ones, NPN, they do work nicely, just do not use the included cable, it is not shielded, so i cut it some 7 to 10 cm from the sensor and wire shielded cable.
- Thank you received: 5331
21 Dec 2020 22:33 #192738
Replied by PCW on topic Prox sensors for plasma table - Advice needed
If you use proximity sensors with the 7I76E, make sure you
select "PNP" type sensors
(NPN types require an external pullup resistor per sensor)
- txtrone
21 Dec 2020 22:58 - 21 Dec 2020 23:15 #192742
by txtrone
Those are heavy duty compared to the toy switches I had been using with my old setup.I am using these Telsa brand switches I brought locally.
Last edit: 21 Dec 2020 23:15 by txtrone. Reason: quote
- txtrone
21 Dec 2020 23:14 #192744
by txtrone
On the low end of their price scale, my local electronics outlet has Omron and RS Pro. These here are $22/each, plus the plug, and wire.
www.alliedelec.com/product/omron-automat...ks04-m1-b1/70330923/
*Plug sold separately, wire not included, some assembly required, see store for full details*
21 Dec 2020 23:29 #192748
FYI, on the 2 new builds using PNP sensors.
Sorry, forgot to mention that.
- txtrone
21 Dec 2020 23:37 #192750
by txtrone
Are they anything like the model in the link from my previous post?
Time to create page: 0.148 seconds
