Prox sensors for plasma table - Advice needed
- Thank you received: 7488
22 Dec 2020 10:12 #192796
Replied by tommylight on topic Prox sensors for plasma table - Advice needed
I use 4mm sensing distance.
Avoid 1mm ones, it is very hard to make them work reliably.
- txtrone
- Thank you received: 106
22 Dec 2020 13:13 #192808
by txtrone
Replied by txtrone on topic Prox sensors for plasma table - Advice needed
- snowgoer540
- Thank you received: 907
22 Dec 2020 13:37 #192810
by snowgoer540
Oh, no, I used the pre-wired cables. I was probably being lazy because 2X the connector price is all but the price of the cable, and I wanted 90° ends for the sensor side...
Replied by snowgoer540 on topic Prox sensors for plasma table - Advice needed
I’m not sure I follow what you mean?
Oh, I was referring to this item from the link you sent.
The following user(s) said Thank You: txtrone
- txtrone
22 Dec 2020 14:21 #192814
by txtrone
Wow, now that I look at their prices more carefully they are way cheaper than what I expected. Thanks for the link!
- txtrone
22 Dec 2020 14:23 #192816
by txtrone
One last question. How did you wire these to your board? Thanks again!
- snowgoer540
23 Dec 2020 01:33 #192909
by snowgoer540
I just followed the schematic in the data sheet for the sensors.
- snowgoer540
29 Mar 2021 21:29 #204099
by snowgoer540
I felt I should follow up on this since I see you are posting that you are wiring up your table.
I had said in an earlier post that I had bought NBN8-12GM50-E0-V1 (NPN) sensors. That's incorrect.
I have NBN8-12GM50-E2-V1 sensors. Which are Normally Open PNP sensors.
If I could do it again, I would get Normally Closed-PNP sensors. (NBN8-12GM50-E3-V1-M1 or similar).
- txtrone
29 Mar 2021 22:04 #204101
by txtrone
I ended up getting Omron E2B-M12KS04-M1-B1 which are NO PNP.
Time to create page: 0.149 seconds
