Prox sensors for plasma table - Advice needed
21 Dec 2020 23:40 #192751 by tommylight
Replied by tommylight on topic Prox sensors for plasma table - Advice needed
Yes, but a LOT cheaper, and i do not mean the price! Omron are good, like really good, like ..... :)
The following user(s) said Thank You: txtrone
  • txtrone
  • txtrone's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Dec 2020 23:46 #192752 by txtrone
Replied by txtrone on topic Prox sensors for plasma table - Advice needed
Just to make sure I understand you correctly, the Omron model I linked to is (in your opinion) a good product at a good price?
21 Dec 2020 23:53 #192754 by tommylight
Lets put it this way:
If i could find them locally any time i need them, i would not bother to think about the price.
Just the time wasted to get the parts here costs me much more.
  • txtrone
  • Platinum Member
  • Platinum Member
22 Dec 2020 00:03 #192756 by txtrone
Ok, I get what you are saying.
There are quite a few options, sort of makes my head spin. What sort of sensing distance am I looking for?
Would you go with the plug in model, or a short pig tail that you would splice?
22 Dec 2020 02:11 - 22 Dec 2020 02:14 #192760 by snowgoer540
Replied by snowgoer540 on topic Prox sensors for plasma table - Advice needed
If you use proximity sensors with the 7I76E, make sure you
select "PNP" type sensors
(NPN types require an external pullup resistor per sensor)
Can you explain this further? I am certain I have NPN prox sensors on my 7i76 (not Ethernet). NBN8-12GM50-E0-V1 Pepperl Fuchs to be specific. But I don’t use resistors. They seem to work. Just want to make sure I didn’t wire them wrong.
Last edit: 22 Dec 2020 02:14 by snowgoer540.
  • txtrone
  • Platinum Member
  • Platinum Member
22 Dec 2020 02:22 #192763 by txtrone
Unrelated to your question... what type of connectors and wire are you using on your sensors?
22 Dec 2020 02:25 #192764 by snowgoer540
I bought the cables and female panel mounts here:
www.avidcnc.com/proximity-sensors-c-48_6...det8ueuj58p09qjifl67
I did not buy the sensors there. I actually got them used on eBay for a steal.
  • txtrone
  • Platinum Member
  • Platinum Member
22 Dec 2020 02:28 #192765 by txtrone
Sweet! Are you using the field wireable connector at all?
22 Dec 2020 02:56 #192768 by snowgoer540
I’m not sure I follow what you mean?
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
22 Dec 2020 09:46 #192793 by rodw
Checked my notes from my original build and PCW suggested then to use a 2.2K 1 W resistor which worked from me. Connect from the +24V wire and the output wire.
Time to create page: 0.364 seconds
