Next steps
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
30 Jan 2021 11:29 #197144 by rodw
Replied by rodw on topic Next steps
I must admit I am a bit overwhelmed by the info available and whilst there is a lot to read, it is sometimes hard to know what it is you need, therefore sometimes guidance is useful. As to sheetCAM I have contacted Les, I found part of my problem was due to the fact I am running the linux version and some Gnome 2 rendering issues. Les has indicated there may be a new version coming out in Feb, that may address the issues.
As to E-Stop there was an E-Stop on my BoB card, I also have a diagram from AgentWD40 (Kyle) from his lowrider2 plasma build that I will use as a wiring guide. Out of interest what number of sub-steps are people using on their steppers?
Have taken yr advice and now the CIG unit it provisioning parts and scrap metal for recycle.
Be sure you get the post processor for sheetcam from this thread
forum.linuxcnc.org/plasmac/38438-plasmac-post-processors
I've never had an issue with Sheetcam on Linux. A lot of the postprocessor workarounds you are used to are no longer necessary.
I run 25x microstepping (5000 steps/rev) with mesa hardware.
Re estop, you have absolute control of what pin does what. I suggest you start a table of inputs and outputs and always update it before you add any wirng to allocate the pin.
The estop pins are in halui right at the end.
linuxcnc.org/docs/devel/html/man/man1/halui.1.html
The following user(s) said Thank You: jnwinkie
31 Jan 2021 23:29 #197255 by jnwinkie
Replied by jnwinkie on topic Next steps
Thanks Tommy; Yes it works OK with Zorin, Mint but not with Ubuntu 16.04 with my config. I run a lot of Gnome 3 stuff.
I will blunder through it but it is good to know Les is updating the libraries.
Cheers
11 Feb 2021 01:04 #198339 by jnwinkie
Well plasma cutter has arrived and have confirmed a 20:1 voltage divider. Do I mod the thcad 5 card and if so how? or do I go the thcad 10 route?
Also it appears that the swifty table uses same machine torch as I have does anyone have speeds and AMP for different materials? I am still curious as to whether folk build the LinuxCNC environ on a fresh disk or co-habit with an existing version using GRUB to select. Thanks again all.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
11 Feb 2021 01:30 #198340 by rodw
Just go to Jaycar and grab a 3.3 M resistor and put that in line with the +IN input to the THCAD. The Wattage is not important.
That will give you a 170 volt full scale which will be fine for the Unimig. It won't go over about 130 volts while cutting so that will work well and still give plenty of resolution.
11 Feb 2021 01:45 #198341 by jnwinkie
Thanks Rod;
I got this sheet from Jasic and yes it seems like 140V is about tops, so I will take that route.
Cheers
11 Feb 2021 02:02 #198342 by PCW
Replied by PCW on topic Next steps
If you already have a 20:1 divider you can change the range of the THCAD-5 to 10V by adding a 100K 1%
series resistor
11 Feb 2021 02:16 #198343 by jnwinkie
Thanks PCW;
So is it the same approach as Rod with the resistor inline with the +IN connection using a 100K rather than a 3.3M?
Cheers
11 Feb 2021 02:33 #198345 by PCW
Yes, 100K added resistor will change the THCAD-5
scaling to 10V full scale.
You would use a much larger value if you connected to the
plasma voltage directy
11 Feb 2021 02:37 - 11 Feb 2021 02:42 #198346 by arvidb
Replied by arvidb on topic Next steps
I am still curious as to whether folk build the LinuxCNC environ on a fresh disk or co-habit with an existing version using GRUB to select.John
Pretty much all Linux distributions support installation to a disk with an existing operating system, with automatic installation and configuration of GRUB to allow dual- (or triple- or whatever) booting.
Here's one article about it: debian.wayoflinux.com/installing/the-installer/dual-booting
It it recommended to backup your existing system first in case something goes wrong with the resize of the existing file system(s) and partition(s).
With one of the installed distros booted, you can mount the other distro's file system to access files between the installed distros.
Last edit: 11 Feb 2021 02:42 by arvidb.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
11 Feb 2021 04:44 #198348 by rodw
My bad. I was in a hurry and worked off the full raw voltage. 100k would give you a 200 volt range, 70k would give you a 170 volt range. Either or won't make much difference.
Good to see they have cutting charts.
Time to create page: 0.338 seconds
