Plasma build basic questions
  • Chris J
  • Chris J's Avatar Topic Author
  • New Member
  • New Member
11 Mar 2021 13:40 #201811 by Chris J
Plasma build basic questions was created by Chris J
Hi all,
I've been planning to build a setup using the Mesa board for over a year now and need to finally get moving.
I've got a Mesa 7I96 as well as a THCAD-10 and a THCAD-5.
I wanted to get some input before I start just so I know what should be expected and what's impossible.
Right now I'm using a low end 5x10 table that for the money paid has more than paid for it self many times over. It's been abused and has given everything that could be expected. It uses a MyPlasm CNC controller.
That being said, there are a few complaints I have about it that I'm hoping my own build can either get rid of, or at least improve on.
The biggest one is what I believe are the steppers losing distance due to drag etc and the system doesn't know this and just keeps cutting. This isn't very fun when large pieces of stainless are being wasted.
Can any DIY builds improve on this? What are my options? I assume stronger steppers would help just through brute force, but how much? Would servos solve this completely or would the software still not know the actual location of the torch?
11 Mar 2021 14:15 #201815 by tommylight
Replied by tommylight on topic Plasma build basic questions
Some lite reading :
forum.linuxcnc.org/plasma-laser/38974-di...rything-in-one-place
forum.linuxcnc.org/plasma-laser/35349-cn...uilding-them?start=0
And a very long build thread with 4 machines by now :
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
As for the servo/stepper thingy, i use both, steppers on smaller machines and servos on bigger ones and retrofits of industrial machines, they work perfectly well when set up properly.
Servos are better due to feedback, steppers are much better as they are more immune to interference from a plasma cutter.
Lately i have been doing a bit more cutting ( not much cutting till now just fix the machines and move on ) so i do a lot of dimensional checks (forgot to tram the machine, wasted some material), and it is all perfectly within 0.1 or 0.2mm depending on what is being done. This is on a stepper machine linked above.
The loosing position issue can always be traced down to bad mechanical construction, binding on the rails, loose screws, not properly set timings and drives, weak motors, direct drive from motor to a big pinion/pulley, or combination of the above.
Grounding and shielding is the single most important part of a plasma machine, often overlooked and ending up in tears. This can also cause lost position on every torch start .
The following user(s) said Thank You: snowgoer540, dvn4life1972, Chris J
  • Chris J
  • New Member
  • New Member
11 Mar 2021 14:25 #201817 by Chris J
Replied by Chris J on topic Plasma build basic questions
Some lite reading :
Hi Tommy,
Thank you for taking the time to respond.
What would you consider a big machine? Our current one is 5'x10' or 1.5m x 3m.
11 Mar 2021 15:32 #201823 by Clive S
Replied by Clive S on topic Plasma build basic questions
Hi Tommy,
This is also a good read
forum.linuxcnc.org/plasmac/37234-plasmac-documentation
The following user(s) said Thank You: snowgoer540, Chris J
11 Mar 2021 15:51 #201826 by snowgoer540
Replied by snowgoer540 on topic Plasma build basic questions
I'll throw this hat into the ring too:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html
The following user(s) said Thank You: Chris J
11 Mar 2021 18:31 #201846 by tommylight
No particular line there, but that one i would consider "middle" sized since i service and maintain an 8X2.5 and a 12X3 meter ones, those i consider big, well 6X2 should be considered big as they usually require forklifts to be moved.
For now i have a 1.5X2.5, a 1.5X3 and a 2X3 meter ones as can be seen on the build log i linked above, the others are gone! :)
The following user(s) said Thank You: dvn4life1972, Chris J
11 Mar 2021 20:54 #201858 by rodw
Replied by rodw on topic Plasma build basic questions
You should not loose steps. That points to poor motor selection, too low a motor voltage, machine binding or acceleration too fast.
So what voltage are you running your dives at?
  • Chris J
  • New Member
  • New Member
12 Mar 2021 12:49 - 12 Mar 2021 13:04 #201954 by Chris J
Please keep in mind the current table I'm using was bought as a low priced system so I know very little about it.
I just want to try to not make the same mistakes building my own.
The motors on the table I'm using are Wantai WT57STH115-4204A. 4.2A 1.8 deg
The drives are Me 2H Microstep Driver DQ856MA
They are set to 4A RMS / 6.6A peak and 3200 pulse.
The power supplies are 48 volts.
I've attached the info I found on the motors. I assume they're nothing great,
There's two on the Y axis and one for Z and one for X. All but Z are setup as a rack and pinion. Don't know the ratio right now.
Last edit: 12 Mar 2021 13:04 by Chris J.
12 Mar 2021 22:36 #202020 by rodw
They look like they should work depending on gantry weight.
I think What Tommy said about grounding might be required. Bolt a seperate wire to a mounting bolt on each motor and run it back to a star ground point.
I would also seperate the motors from the racks so you can push the gantry around. I can push mine with my little finger like this. If there is any binding, work out what it is and fix it. Then remove the motors so avoid any back emf and do the same thing with the rack and pinion engaged. Perhaps this is the first step. I have a little bit of binding on my X axis rack and pinion when engaged. I think becasue of crappy rack and pinion.
The following user(s) said Thank You: tommylight, dvn4life1972, Chris J
  • Chris J
  • New Member
  • New Member
15 Mar 2021 11:55 #202336 by Chris J
Removing the motors so I can feel things move on their own is a good idea, I didn't think of that.
Something I can't wrap my head around is cutting 1/4" 304 SS I had issues with round holes not even being close to round and I thought it was because the plate was warped. Yet, I just tried burning a bunch of test holes in some 1/4" steel and they came out perfect. I then put the plate on a pretty steep angle and they still came out good. So, I don't know if it's an issue with SS, or that specific SS, or what's going on.
I'm running a Hypertherm Powermax 125 and was using 45A at those times. I usually get a pretty good cut, but, there's sometimes where not so much.
Time to create page: 1.322 seconds
