Plasma build basic questions
5 years 7 months ago #202837 by dvn4life1972
Speaking as a former career welder, higher amperage (temperature) with correct travel speed will yield better results on thicker material than running at the lowest possible amperage, much the same as when welding as the heat input and travel speed principles are essentially the same in most cases. There's also the added benefits of reduced tendency for warping of the material, as well as higher productivity.
Time to create page: 0.045 seconds
