- Thank you received: 4153
rodw wrote: They look like they should work depending on gantry weight.
I think What Tommy said about grounding might be required. Bolt a seperate wire to a mounting bolt on each motor and run it back to a star ground point.
I would also seperate the motors from the racks so you can push the gantry around. I can push mine with my little finger like this. If there is any binding, work out what it is and fix it. Then remove the motors so avoid any back emf and do the same thing with the rack and pinion engaged. Perhaps this is the first step. I have a little bit of binding on my X axis rack and pinion when engaged. I think becasue of crappy rack and pinion.
rodw wrote: I've not cut much stainless, only thin stuff.
I vaguely remember from my cut charts that you need a "hotter" torch for stainless vs mild steel.
One commercial guy I knew who cut all day every day had a rule of thumb he had which was 10 amps per mm of steel. So by his benchmark, 45 amps is too low, I'd try 60-80 amps depending on available consumables..
