- Thank you received: 327
Joco wrote: When you say "half the resistance on each wire" if we take an example where I am setting up a THCAD-10 to max scale at 200V then I believe I need 1.9M Ohm (based on the forumula in the manual). So per you suggestion I have 950k Ohm on the POS and NEG input wires of the THCAD - yes?
Joco wrote: Re the metal box on the back of the plasma unit, that was what I had been thinking but changed it based on the non HF description in the plasma primer.
Joco wrote: Rod - plasma primer is awesome. Great job.
Get the logic for install close or in machine. If inside the machine assume you just have it on mounting bracket? Not in a box?
For hypersensing do you also put that THCAD in the plasma unit given its going to have wires to it with cutting voltage on them? If so it might start to get a little crowded. The cigweld unit is pretty compact already. But it will be easier to visualise when I get the parts.
Question on control board, obviously going with mesa but 7i96 or 7i76e? I like the tighter price of the 7i96 but will I run into issues with limited IO?
Cheers - J
