CIgweld Cutskill 60 - adapting to CNC use
5 years 7 months ago #204348 by rodw
It sounded like you wanted to build a voltage divider and use the THCAD to When the THCAD scaling resistor is all you need per the formula in the thcad manual.
The following user(s) said Thank You: Joco
5 years 2 weeks ago - 5 years 2 weeks ago #223162 by Joco
I have managed to have a little win with the Cutskill.  I decided to have a crack at splicing into the torch trigger connection located here on the circuit board.
You could do the T splices into the wires but I decided tofix wiring into the plug itself.
So after some mucking about I ended up with an external button as my "human powered relay".
Then connected the machine torch I had from AliExpress.
Here it is for anyone else interested in what to get for a Cutskill style plasma power source:
www.aliexpress.com/item/1005002211780814...1.0.0.27424c4djYGtBV
So .. after a little bit of trepidation as this was the VERY first time I was trying to fire this torch, I gave it a crack.
40AMP setting, air pressure per the manual.  And it WORKED. image missing /media/kunena/emoticons/w00t.png
Last edit: 5 years 2 weeks ago by Joco. Reason: on going fights with this stupid backward step of an editor.
5 years 2 weeks ago - 5 years 2 weeks ago #223165 by Joco
As a quick followup note, if you decide to purchase the torch I linked you NEED to request two of the pins to be changed.  Check their mappins and the mappinsg in your manual and request that change as part of the notes to the seller on placing the order.  Also check they are still offering to do these customisations.
In my case my request for the Cutskill 60 was:  Please change ARC pins from 1,4 to 5,6
Cheers - James.
3 years 2 weeks ago #282990 by aussietom
Hiya James,
Just checking if you progressed on this any further and thought the cutskill 60 + the torch was a good fit for plasma cnc table or not?
Thanks,
-Tom
3 years 2 weeks ago #283219 by Joco
Check out my plasma table build thread.   From this point one we get more into final adjustments to the cutskill.
forum.linuxcnc.org/show-your-stuff/42118...rea?start=150#281696
If you are prepared to do the adjustments (minor at that) then its a pretty reasonable option given it will deliver 60A.   Machine torch is a key addition.  I got a PTM-80 but there are PTM-60's out there.  For some reason more expensive.  And when you get it you need to make sure the pins on the adpator are correctly mapping to the the pins on the cutskill.  The default for these torches is not always what you want.  When I got my PTM-80 torch having it custom wired for the Cutskill was an option. I just needed to spell out what pins I wanted for connected to trigger and consumable installed ok.
Splicing into the Trigger circuit wasn't hard and installing the thcad and a relay into the unit and wiring it up to my own custom CNC port took a little itme to be careful but ultimately wasn't difficult.
Now it looks like it came from factory with a cnc port and the conneciton is all operating with an internal THCAD-10 for reading the voltage.
Cheers - J.
3 years 2 weeks ago #283220 by Joco
Here are some pics from the internals of the cutskill 60 build/adjustment.
Time to create page: 0.293 seconds
