(Solved) QTPlasmac scaling issue
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Apr 2021 12:18 - 14 Apr 2021 17:56 #205778 by bevins
(Solved) QTPlasmac scaling issue was created by bevins
I am havng an issue I am up to the latest QTplasmac and I went to open a file and it was scaled somehow. I loaded same file in plasmac config and it was fine.
Is there a scale factor somewhere I missed?
see the pics between QTplasmac and plasmac loading the same file.
Last edit: 14 Apr 2021 17:56 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 12:26 #205780 by bevins
Replied by bevins on topic (Solved) QTPlasmac scaling issue
I put the OFFSET_AV_RATIO to 0,
Still has the same behaviour. I think the X is scaled.
13 Apr 2021 12:32 #205783 by snowgoer540
Replied by snowgoer540 on topic (Solved) QTPlasmac scaling issue
Can you post the backup from plasmac as well?
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 12:41 - 13 Apr 2021 12:42 #205784 by bevins
I did, its in the first post.... oops, yeah my mistake. Ill post in a sec
Last edit: 13 Apr 2021 12:42 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 12:44 - 13 Apr 2021 13:05 #205785 by bevins
Plasmac config attached
Last edit: 13 Apr 2021 13:05 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 12:49 #205787 by bevins
Here is an image from conversational screen. Circle 5" diameter, you see in the preview it is scaled on the X.
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 15:02 #205803 by bevins
snowgoer540: Were you able to replicate this?
  • bevins
  • Platinum Member
  • Platinum Member
13 Apr 2021 23:23 #205835 by bevins
Am I the only one having this issue?
13 Apr 2021 23:27 - 13 Apr 2021 23:34 #205836 by snowgoer540
I've no way to simulate any of this at work. I just replied quick to save you time in case someone wanted to see your other config.
Not sure what your issue is.
It works fine here on v1.0.13:
Last edit: 13 Apr 2021 23:34 by snowgoer540. Reason: version typo
14 Apr 2021 02:45 - 14 Apr 2021 06:01 #205841 by phillc54
Replied by phillc54 on topic (Solved) QTPlasmac scaling issue
Try either commenting out this line in the .ini file
GEOMETRY = xxyz
or changing it to:
GEOMETRY = xyz
forum.linuxcnc.org/21-axis/38334-2-8-0-p...ction?start=0#156597
Last edit: 14 Apr 2021 06:01 by phillc54.
Time to create page: 0.267 seconds
