New Plasmacutter
- Giuseppe
- Thank you received: 9
24 Jul 2021 12:50 #215771
by Giuseppe
Replied by Giuseppe on topic New Plasmacutter
today i got a new problem. at the moment my plasma cutter does a probing with every new cut.
the consequence of this is that when the torch comes to a point where it has already been cut and makes the next cut the torch travels underneath the material during probing because it does not encounter any resistance. because there is no material at this point
how do you solve the problem?
- snowgoer540
- Thank you received: 907
24 Jul 2021 13:21 #215773
by snowgoer540
Replied by snowgoer540 on topic New Plasmacutter
I think what you’re looking to do is skip the probe if the last probe was within a certain distance of the first probe.
If so, I think this will help you:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_ihs-skip
IHS skip distance is set on the parameters tab in the probing section.
Hope that helps
Hope that helps
The following user(s) said Thank You: CNCFred
- Thank you received: 7488
24 Jul 2021 14:01 #215781
Replied by tommylight on topic New Plasmacutter
If i understand correctly, that is a CAM issue, torch should never probe where there is no material.
- snowgoer540
24 Jul 2021 14:06 #215783
by snowgoer540
Reading it again, I’d have to agree with you Tommy. No idea what I was picturing the first time
On vacation… maybe I should stick to that haha
- Giuseppe
24 Jul 2021 14:32 - 24 Jul 2021 14:33 #215785
by Giuseppe
I think you are not totally wrong snowgoer540
@tommylight
The problem is not in the code, there is material. but it press down by the wight of the torch.
so i think i have to use the ihs parameter to disable the probe
@tommylight
Last edit: 24 Jul 2021 14:33 by Giuseppe.
24 Jul 2021 18:06 #215801
Or use a spring ?
- Giuseppe
24 Jul 2021 18:42 #215802
by Giuseppe
I think i will realise a ohmic probe later. but for the moment. How can i make it that plasmac makes only one probe at start and no more
during the job?
Should i use ihs skip?
during the job?
- phillc54
- Thank you received: 2100
24 Jul 2021 23:48 #215821
by phillc54
Replied by phillc54 on topic New Plasmacutter
If your material gets pessed down by the torch then it means it must be bending up during cutting so IHS Skip wont help you for that situation. You need stable material to rely on IHS Skip.
- Giuseppe
25 Jul 2021 08:29 #215843
by Giuseppe
Ok, last question for this problem, how can i say the machine to only one time on start a probing?
And not on every cut in the job.
Time to create page: 0.196 seconds
