New Plasma build in OZ
5 years 3 months ago #214358 by 34by151
Replied by 34by151 on topic New Plasma build in OZ
Thats very much like what im planning.
The only real difference will be making the area between your tray and the rails a drain. For me fixes 2 issues, overfilling the table and splashing over the sides.
I will be repourposing the same setup tanks and pumps from the old table.
A pair of IBC's for the tanks (located outside). The pump is actually a 2hp pool sand filter setup with glass beads in the filter. Pump inlet and outlet connected to a manafold with 50mm irrigation solenoids. This allows fill and drain, tank pump out and tank recurculate. I find the filter works great in getting rid of the soot in the water. Works best with the 2 tanks.Circuate water for 20mins and it turns from black to allmost clear. A quick backwash of the filter into the scrap bin and its done.
  • thefabricator03
  • New Member
  • New Member
5 years 3 months ago #214360 by thefabricator03
Replied by thefabricator03 on topic New Plasma build in OZ
Thats interesting about your two tanks,
I have done the same and used a large pump to move the water. I originally wanted to use air pressure to move the water but that turns the tank into a pressure vessel which then comes with its own set of safety standards you must conform to. Its not worth the hassle in a workplace to have any unnecessary pressure vessels as they need to be registered and inspected regularly.
5 years 3 months ago #214364 by 34by151
Exactly on the pressure vessel.
One tank will be just under the table volume
I went IBC's as they are cheep, under $100 near new and can be easily moved if needed.
My shop has a 1m retaining wall along one side. So the tanks are below ground level for quick gravity feed if needed.
Uning 2 tanks allows the filter to circulate between the tanks removing the soot. Does not take long to do and works really well. Pool pumps a re cheep as well and move a lot of volume. They also handle 10mm solids but the inlet on the table should be screened anyway so your only really dealing with soot in the pump.
A sand filter and pump willmove 1000L in about 4 minutes and cost about $600 new
5 years 3 months ago #214368 by rodw
Replied by rodw on topic New Plasma build in OZ
on the subject of side mounted rails, I mounted mine lower on a steel plate that rested on grubscrews at each end to allow it to be aligned before clamping off. This also would have let me shim the mounting plate but it was not required as we were able to make a temporary "gantry mounted upside down when welding to check for alignment
5 years 3 months ago #214998 by 34by151
Finally got most of it into Solidwoks
I havent drawn everything in and will need to do that before I can do some FEA testing.
Here is the basic design
Working area is 3300mm x 1900mm
Gantry has a parking area
A sump is located at the far end under the parking area
Water pan is flat to make cleanout easy
Rails are on the bottom
Legs are on height adjustable casters
Rails are removable and sit in 3 removable trays
Around the edge is a splash gutter
Need to finish drawing it up and run some tests
I also plan to use timimg belt drive for X and Y
First quotes are comming in for the Hwin Rails, hope to order them soon and get building
Cheers
Jim
5 years 3 months ago #215006 by rodw
Looks good..
I'm a bit concerned about your casters.  The threaded extension rod seems quite small. I used 4 x 300 kg casters but also made provision for adjustable feet on an M30 thread. Needless to say, I have removed the casters due to excessive wobble. Even without a water tray, its darn near impossible to move my 4 x 4 table on the casters.... but they were handy until I finally got it to its final location...
Please share your Hiwin pricing when it comes in. I added a new Chinese supplier yesterday who list it. I might be able to help. I ordered a Z axis as a sample so will see what it looks like when it arrives.
