New Plasma build in OZ
5 years 3 months ago #215915 by 34by151
Replied by 34by151 on topic New Plasma build in OZ
To go another direction on what I want included
Bed to be flat, no obstruction to loading on 3 sides
Easy to align sheets
Gutter beween the bed and cutting area to prevent water spillage.(I cant count how many times Ive also overfilled the water)
Rails inder the bed to keep them protected and as dust free as possible
Curved slats to help with light sheets and minimise wear on straight cuts
Filtration on the water, used a pool filter and glass beads to do this before, going the same again.
Remote lubrication system. Looking at 3 Automatic Lubrication Pumps, one for each axis.
Ability to add a scribe, probally wont add it initally though. Just going to be ready but both scribe and torch have to operate over the full cutting area.
Wider table to allow for 1800mm wide sheets. Also planning for a camera
Ability to move the table (using the fork or the tractor). This is for ocasional cleanup under the table and or access to other maintence work in the shop. IE sooner or latter the LED high bays will need to be accessed above the table. These are 6m up, so it would ne nice to be able to move the table for the sissor lift to get in.
Grantry as light as possible
Working though this in solidworks now. Testing various designs with varying alloy RHS beams. Mainly looking at the stiffness and fatigue and weight to start with.
Thats the major things
5 years 3 months ago #215926 by 34by151
Prices in from industrial dynamics
4000mm rails $492.10 each
Carrages $58.10 each
Seal/Scraper kit $28.07 each
Shipping to Sunshine coast $170
Prics ex gst
5 years 3 months ago #215945 by tommylight
Replied by tommylight on topic New Plasma build in OZ
Did you check the prices for supported round rails ?
They are much easier to work with and will tolerate fine plasma dust, HGR/HGH foes not, even a single spec getting inside them will lock them solid.
Happened once to a client while cleaning he pushed on the wipers.
5 years 3 months ago #215947 by rodw
Replied by rodw on topic New Plasma build in OZ
Thats probably a fair price. I was quoted USD $45 a metre for genuine Hiwin HGR25 ex China. 4.0 m lengths would have to come by sea as they are too long for air freight. Thats not difficult through my freight forwarder but there is a MOQ of 10 lengths. At a guess there would be about AUD $150-$180 per length shipping so you'd need to add a fair bit more to the order to get the shipping down...
5 years 3 months ago #215949 by 34by151
I can get SBR20 with 2 long carrages for $490 each
5 years 3 months ago #215970 by tommylight
Not much difference there, here they are about 40% cheaper than HGR.
Time to create page: 0.065 seconds
