Ultimate guidance to avoid Electromagnetic Interference
5 years 3 months ago #216320 by rodw
More information please.
What plasma cutter (with URL for it)?
What control hardware?
What sized motors?
What voltage for motors?
What power supplies are you using in the control box?
What Plasmac Mode?
How are you obtaining an ArcOK?
If you run that job with the torch disabled, does it follow the correct path?
5 years 3 months ago #216331 by shpatb
Thanks for reply Mr.Rod
1.stahwerk cut 70 igbt
2.2x breakoutboards
3.3Nm stepper motors
4.36V DC
5.Act motor psu-s
4.latest plasmaC
Yes with torch disabled it runs perfectly . i have dual configs with mach 3 and PlasmaC , perfectly on both.
Attached some pictures to make it more clear.
regards Shpat
5 years 3 months ago #216332 by shpatb
Today ill order new plasma of CNC stamos s85 , will change the cables of motors to shielded ones , will change the power supply cable of my shop from 5G2.5 copper to 4x25 alu ,Will add a mesa controller , if this doesnt solve this problem ill definetely sell this machine for scrap.
5 years 3 months ago #216333 by rodw
Looks like its a HF start machine?
Lower voltage on the BOBs is not helping.
Make sure you use 24V with the mesa for greater noise immunity.
Move your PC away from the control box as the ethernet cable will add more isolation
Add a RFI filter to the mains power entering the control box.
Try and run your shielded stepper cables right to the stepper drive and ground the shield right there.
Try and earth to the motor across to your existing earths.
The following user(s) said Thank You: shpatb
5 years 3 months ago - 5 years 3 months ago #216334 by shpatb
Thank You for Your help mr.Rod.
Last edit: 5 years 3 months ago by shpatb.
5 years 3 months ago #216336 by rodw
Just found this pic. Notice the grounding point. There must be a reason for it...
Time to create page: 0.310 seconds
