Torch isn’t firing
- Aldenflorio
- Thank you received: 15
14 Mar 2022 20:44 #237236
by Aldenflorio
Replied by Aldenflorio on topic Torch isn’t firing
1: is this right?
2: 0v= 121.5 KHz 10v= 944.7 KHz
3: Done
4: Scale= 0.01943635 offset= 3,796.8750
5: doing it now
I will test that. thank you, i deeply appreciate this so much. Does my plasmac need to be updated first for this all to work?
3: Done
5: doing it now
- Aldenflorio
14 Mar 2022 21:02 #237238
by Aldenflorio
I think it worked! Time to run some test cuts
- phillc54
- Thank you received: 2100
14 Mar 2022 22:27 #237250
by phillc54
You would need 2.9 if you wanted to move to QtPlasmaC.
Replied by phillc54 on topic Torch isn’t firing
No, PlasmaC runs only on 2.8.so i have to upgrage my whole system to linuxcnc 2.9? i thought i just had to upgrade plasmac?
- Aldenflorio
14 Mar 2022 22:35 #237253
by Aldenflorio
Oh okay. I’m not sure if I’m into all that right now. Though will what I did work with the plasmac I have?
- phillc54
14 Mar 2022 22:52 #237255
by phillc54
It should do. But as mentioned previously there have been some bugfixes since the version you are running.
- Aldenflorio
14 Mar 2022 23:29 #237261
by Aldenflorio
Okay thank you. Does my hal file look right? I posted it above
- phillc54
14 Mar 2022 23:32 #237262
by phillc54
That looks OK for PlasmaC in Mode 1 with a float switch.
- Aldenflorio
14 Mar 2022 23:48 - 15 Mar 2022 00:06 #237264
by Aldenflorio
So everything works except arc ok. The thc is reading, floating head of course is working, arc is established. But no arc ok. So after 3 attempts it stops.
I checked the connections hal an it seemed to match up. The wires are going to input 10. Again, it’s wired just like the picture
Last edit: 15 Mar 2022 00:06 by Aldenflorio.
- Aldenflorio
15 Mar 2022 00:38 - 15 Mar 2022 00:39 #237276
by Aldenflorio
I figured it out of sorts. I had some wires wrong, though now I’m getting thc velocity lock.
Last edit: 15 Mar 2022 00:39 by Aldenflorio.
- snowgoer540
- Thank you received: 907
15 Mar 2022 01:22 #237282
by snowgoer540
Replied by snowgoer540 on topic Torch isn’t firing
Update to the latest version of PlasmaC using this process: linuxcnc.org/docs/2.8/html/plasma/plasma...tml#_standard_update
You'll only have to do it once as there wont be any more PlasmaC updates after that.
Time to create page: 0.129 seconds
