Laser Head Height Sensor – Looking for a Beta Tester
1 year 4 months ago #330536 by bcorley
Thanks for the info. From what I gather, reading previous posts, the periodm function requires linuxcnc 2.10. I'll have to make up another test unit for that. Also, I'm running a 2msec servo thread. Is that going to be an issue?
1 year 4 months ago #330541 by PCW
It does make the resolution of the encoder frequency  a bit better than at 1 ms
but the periodm does not care as you specify the number of period averages.
The following user(s) said Thank You: prokopcio
1 year 4 months ago #330558 by prokopcio
I agree with you. The topic is not easy.
I had to put the project on hold for a while because the sensor had problems with some heads (precitec) that contain electronic components inside nozzle holder. This effectively prevented my sensor from working.
Now I have dealt with it and it seems to work correctly, so I want to put the device into production.
If you have time and want, I will prepare a test device for you.
I want the device to work at the highest level, so any feedback is valuable to me.
The tests were very promising.
1 year 4 months ago #330669 by phino
Interesting product. Any idea if your sensor works with PLLA (plastic/polymer)?
Can't test at the moment as the intended laser systems aren't ready yet, but might be interested in testing and/or purchasing units soon.
1 year 4 months ago #330678 by prokopcio
the device was designed for metal materials. It was tested with other materials and although it works, the precision of the measurement is not satisfactory for me to sign under it as a manufacturer. It works quite well with wood, but a change in structure (a knot in a board) can significantly change the capacitance.
so the answer is: No, the device is designed only for metals.
The following user(s) said Thank You: phino
1 year 4 months ago #330802 by bcorley
A test device would be great. What information do you need to get it to me?
Time to create page: 0.171 seconds
