I was thinking about differential signals and if there is such a need I will introduce them, we will see after the tests. There was only one obstacle - I wanted to leave the size of the device exactly like most BCL type sensors so that it would fit perfectly in the place designated for it. I did not find a suitable connector convenient to use to accommodate so many cables. I thought about RJ45 but it gave rise to other problems.I converted the bcl-amp output to a differential signal (max485), at a long length it works much more stably and reliably. You should do the same (I understand that your frequency is linear and depends only on the height). A couple more questions, your sensor have temperature stabilization?
I will reveal the details that I found out on my own and were hard to find on the Internet:As for AD7745/AD7746, I tried to use it as a controller for gas burners. It was not easy because it worked on the desk, but during cutting, the gas changed the parameters very much and the AD7745/AD7746 measurement method was not suitable.1. It is not suitable for lasers because the reading is too slow 90Hz.To make sense for Lasers, the absolute minimum sampling is 500Hz (2ms), I have 3650Hz sampling but I do not want/cannot reveal why this value is chosen and it should be selected for a specific type of processing.2. AD7745/AD7746 have a measurement range of 17pF (60pF tollerant), which is definitely too little because the parasitic capacitances on the wire, head, etc. are 50-200pF3. The useful measurement range of the distance is 0.1pF - 30pF, although for some types of nozzles the range may be wider4. I chose the method of measuring the capacitance charging time, although I also experimented with measuring the frequency as in BCL-AMP BCS, which was a bit less stable but also very good.5. Unfortunately, I did not find any ready-made circuit like AD7745/AD7746 that would be suitable, and I had to design everything from scratch.
