- Thank you received: 26
could you give an example / link ?Also I noted that on some laser cutting solutions the capacitive BCL-AMP is being superceded by amplifiers with a 0-10 volt signal?
Hi PCWI would say a couple hundred KHz so pretty much any encoder interface could work.
Also better if its a square wave so it asks the least of the frequency/period counter.
An offset frequency is good also so you don't lose bandwidth near 0 frequency.
