Air Drill/ Air Scribe
- thefabricator03
- Visitor
06 Sep 2019 06:15 #144322
by thefabricator03
Air Drill/ Air Scribe was created by thefabricator03
Hi Guys,
I have taken rodw's advice and purchased an air drill to add to my plasma machine for drilling small holes,
www.totaltools.com.au/air-tools/air-dril...keyed-drill-si2015ad
I want to be able to switch between my air scribe and drill by mounting them on the same slide with a quick release lever to change them out.
In PlasmaC, what would be the best way to set up the drill. I take it it will need to have its own tool number and we will change tools like we do for the scribe and pierce function.
I dont know if Phill has any room left for adding delays and such in the GUI's but it would be handy if we could have a set of rules similar to what we have for the scribe function.
- pl7i92
- Thank you received: 358
06 Sep 2019 06:28 #144324
by pl7i92
Replied by pl7i92 on topic Air Drill/ Air Scribe
airdrill do you realy got that thick sheets
we here in Germany and in the Shop
go with the plasma to 12mm with a 5mm offset to the contour
up to 25mm we start at 3mm Height 10mm outside the contour and go 25+mm parallel/circle this then burns its way thrue the sheet
then move in contour / this is pre info burned so you know how long it takes to go thrue and edit the postprocessor LINE Bevor cut
- thefabricator03
- Visitor
06 Sep 2019 06:37 - 06 Sep 2019 06:43 #144327
by thefabricator03
Replied by thefabricator03 on topic Air Drill/ Air Scribe
I have tried cutting out small holes with the plasma but they are pretty sloppy compared to drilling them. I wont be using it on thick stuff just mostly sheet metal that I need the round hole to fit it up to other parts. On thick parts I usually do a spot peck and then rotor broach the hole or punch the plate on our iron worker for holes that need to be 100% round with no taper.
Last edit: 06 Sep 2019 06:43 by thefabricator03.
- Thank you received: 4149
06 Sep 2019 09:40 #144354
Replied by rodw on topic Air Drill/ Air Scribe
See Phill, I told you you'd be onto this before long!!!
I'm a bit worried about being blamed for this if it ends badly. I was just musing becasue I had no idea about this at all!
And now all of a sudden my musings have been promoted to advice!
Hi Guys,
- thefabricator03
- Visitor
06 Sep 2019 09:47 #144355
by thefabricator03
Lol, You might end up with the credit when it turns out better that anyone expected.
06 Sep 2019 10:00 #144357
Make it happen Stefan! I've got some 300mm long air rams that are strong enough to lift me off the ground if you want to do it from a distance! I'm just not sure how you'd limit the down travel so it does not poke holes in your water table though!
- phillc54
- Thank you received: 2100
06 Sep 2019 10:19 #144360
by phillc54
That's where I get hung up as well...
Replied by phillc54 on topic Air Drill/ Air Scribe
- thefabricator03
- Visitor
06 Sep 2019 10:24 #144361
by thefabricator03
Thats easy solved. Mount the rams in the air so that at full stroke the drill bit only just passes the slats. See anything is possible
- thefabricator03
- Visitor
06 Sep 2019 10:30 #144362
by thefabricator03
Thinking about this a bit more and sharing a air slide might be a problem since its linked to the air scribe.
Maybe I am better off building a new slide for the scribe and using the other slide for the drill.
But that means more solenoids and regulators and air lines..
- Thank you received: 7485
06 Sep 2019 10:49 #144365
Replied by tommylight on topic Air Drill/ Air Scribe
Time to create page: 0.155 seconds
