Air Drill/ Air Scribe
- Thank you received: 4149
06 Sep 2019 12:49 #144375
Replied by rodw on topic Air Drill/ Air Scribe
Do you need a slide for a drill when you see how much the average drill press spindle wobbles around? I think the air rams I have have a 16mm shaft with a 12mm thread on the end. So it does not move much...
- Thank you received: 4654
11 Sep 2019 00:31 #144762
Most cylinders I have seen have slots to mount hall switches (they put magnets in the pistons) so it should be pretty easy to go to a retract cycle at an adjustable point.
Replied by andypugh on topic Air Drill/ Air Scribe
[Make it happen Stefan! I've got some 300mm long air rams that are strong enough to lift me off the ground if you want to do it from a distance! I'm just not sure how you'd limit the down travel so it does not poke holes in your water table though!
Time to create page: 0.168 seconds
