Probe test problem
01 Jan 2020 03:04 #153692 by snowgoer540
Replied by snowgoer540 on topic Probe test problem
It shows the same behavior in both tabs. The weird thing is it worked the very first time I ran after the configurator did its thing.
Honestly I’m not sold on gmoccapy, was thinking of making another config to try axis.
04 Jan 2020 20:23 - 04 Jan 2020 20:24 #154019 by snowgoer540
You have a couple of issues with homing.
HOME_SEQUENCE is negative only for joints that need to home in sync.
Switched over to Axis today, and I remembered why I did a negative sign (-) before all joints, regardless of whether or not synchronized movement is necessary. - in front of a homing sequence also forces you to home that joint before you can move any of them. I dont want any movement to be possible prior to homing, so that's why I did that.
I started at 1 instead of 0 because I dont think you can have -0 (but I may be wrong about this, I dont know what the default keyboard values are for Joint 3 movement to try it out, since in joint mode left and right arrows = joint 0, up and down arrows = joint 1 and page up and page down = joint 2).
Just figured I'd follow up in case it helped someone, or there is flaw in my logic.
Last edit: 04 Jan 2020 20:24 by snowgoer540. Reason: clarity
04 Jan 2020 22:02 #154033 by phillc54
Replied by phillc54 on topic Probe test problem
joint 3 = [ and ]
in Axis go Help - Quick Reference, that shows all the keyboard shortcuts.
05 Jan 2020 01:42 #154058 by snowgoer540
joint 3 = [ and ]
Thanks for the help!
I confirmed, negative sign on a 0 has no effect.
Time to create page: 0.355 seconds
