Pause option capabilities
  • LuisGZ
  • LuisGZ's Avatar Topic Author
  • Junior Member
  • Junior Member
21 Oct 2019 21:11 #148493 by LuisGZ
Replied by LuisGZ on topic Pause option capabilities
Great addition, exactly what I was trying to describe. I'll update and give it a go, thanks a lot!
  • LuisGZ
  • Junior Member
  • Junior Member
22 Oct 2019 14:39 #148543 by LuisGZ
A little update, I tried a new configuration both on Axis and Gmoccapy and I'm unable to run it. In Axis I get this error:
In Gmoccapy when I home the machine and I click on Change Consumables it get Bad character 'c' used
I'm not entirely sure I'm missing something, is someone else having problems?
22 Oct 2019 21:58 - 22 Oct 2019 22:29 #148560 by phillc54
Replied by phillc54 on topic Pause option capabilities
Could you post your .ini file.
Edit: did you run the Configurator and do an Upgrade?
Edit2: in Axis there should have been "invalid consumable change feed rate" message just above the error you posted. Can you check the "BUTTON_n_CODE" line in your .ini that has "change-consumables" in it for "Fnnn"
Edit3: The button should not be enabled unless paused during a program. Can you check the you have "change-consumables" in the "BUTTON_n_CODE" line of the Gmoccapy .ini file.
Last edit: 22 Oct 2019 22:29 by phillc54.
  • LuisGZ
  • Junior Member
  • Junior Member
22 Oct 2019 22:33 #148563 by LuisGZ
Sure, here is the code. I made a profile using just the simulator, so I didn't use the PlasmaC configurator, both for Axis and Gmoccapy.
Also, I set up f to 1000 as shown in the example.
# see notes below on how to marry this config into a working config
# this section only reqired if using the sim testing panel
[APPLICATIONS]
DELAY                   = 3
APP                     = ./test/plasmac_test.py
# required
[PLASMAC]
# sets the operating mode, if not specified the default is 0
# 0 = use arc-voltage-in for arcOK and THC (no need to connect arc-ok-in, move-up-in and move-down-in)
# 1 = use arc-ok-in for arcOK and arc-voltage-in for THC (no need to connect move-up-in and move-down-in)
# 2 = use arc-ok-in for arcOK and move-down-in + move-up-in for THC (no need to connect arc-voltage-in)
MODE                    = 0
# enable(0) or disable(1) the plasmac config page, if not specified the default is enabled
CONFIG_DISABLE          = 0
# the font for the Axis GUI, if not specified 'sans 10' will be used
# valid font sizes are from 10 to 15
FONT                    = sans 11
# the window size for the Axis GUI, 0 = minimum size to suit font, 1 = maximized
MAXIMISED               = 0
# the theme for the Axis GUI tabs, if not specified the system theme will be used
THEME                   = Clearlooks
# percentage of cut-feed-rate used for paused motion speed
PAUSED_MOTION_SPEED     = 50
# torch on time when manual pulse requested
TORCH_PULSE_TIME        = 1.0
# for the five user buttons
# the text that appears on the button
# for multiple lines, split the lines with a \
# e.g. BUTTON_1_NAME = Clear \ Coordinates or
#BUTTON_n_NAME
BUTTON_1_NAME           = Ohmic\Test
BUTTON_2_NAME           = Probe\Test
BUTTON_3_NAME           = Z\To Top
BUTTON_4_NAME           = Load\Sheet
BUTTON_5_NAME           = Change\Consumables
# the command that the button sends
# e.g. BUTTON_1_CODE =  g0 x0 \ g1x10f100 \ g0x0
# ini file settings can be used, must be within {} and with a space between
# e.g. G0 X{JOINT_0 HOME}
# e.g. G0 X{JOINT_0 HOME} Y1
# e.g. G53 G0 Z[{AXIS_Z MAX_LIMIT} - 1.001]
# for an external command, precede the command with %
# e.g. %halshow
# external commands and gcode may be on the same code line
# e.g  %halshow \ g0x.5y.5 \ %halmeter
# there are four special commands:
# probe-test, ohmic-test, cut-type and change-consumables
# using these will set/reset the corresponding hal pin in the component
# adding a number after probe-test will hold the pin for that number of seconds
# e.g. probe-test 15 will hold the halpin on for 15 seconds
# cut-type switches between pierce & cut and pierce only and will reload the current program
# change-consumables moves the torch to the specified machine coordinates when paused
# e.g. change-consumables x10 f1000 will move to X10 at 1000 units per minute
# valid entries are Xnnn Ynnn Fnnn. F is mandatory and at least one of X or Y are required
#BUTTON_n_CODE
BUTTON_1_CODE           = ohmic-test
BUTTON_2_CODE           = probe-test 10
BUTTON_3_CODE           = G53 G0 Z[{AXIS_Z MAX_LIMIT} - 1]
BUTTON_4_CODE           = G53 G0 X{JOINT_0 HOME} Y1
#BUTTON_5_CODE           = cut-type
BUTTON_5_CODE           = change-consumables x10 y10 f1000
# this section required as is for removing z axis moves from the loaded gcode file
# this is optional and if used then plasmac_gcode.py needs to be set as executable
[FILTER]
PROGRAM_EXTENSION       = .ngc remove z axis stuff
ngc                     = ./plasmac_gcode.py
[RS274NGC]
RS274NGC_STARTUP_CODE   = o<metric_startup> call
PARAMETER_FILE          = metric_parameters.txt
# required, ./ must be in this path
SUBROUTINE_PATH         = ./:../../nc_files/subroutines
# required for reading ini and hal variables
FEATURES                = 12
# required for our material change
USER_M_PATH = ./
[HAL]
# required
TWOPASS                 = ON
# for a working config point this to your machine hal file
HALFILE                 = machine.hal
# required
HALFILE                 = plasmac.hal
# required - see comments in plasmac.hal
HALFILE                 = metric_plasmac_connections.hal
# required
HALUI                   = halui
# for a working config:
# delete the [FILTER], [RS274NGC] & [HAL] sections (if they exist) in your working configs ini file
# edit the [HAL] section above so that HALFILE points to the machine hal file in your working config
# copy everything above these comments into your working configs ini file
# copy all the EMBED_TAB_ stuff below to the [DISPLAY] section in your working configs ini file
# edit the [AXIS_Z] section of your working configs ini file (see [AXIS_Z] section below for notes)
# look at comments in plasmac.hal for recommendations on how to set up your connections
[DISPLAY]
DISPLAY                 = axis
POSITION_OFFSET         = RELATIVE
POSITION_FEEDBACK       = ACTUAL
MAX_FEED_OVERRIDE       = 1.5
PROGRAM_PREFIX          = /home/boyser/linuxcnc/nc_files
INTRO_TIME              = 1
CYCLE_TIME              = 0.1
INCREMENTS              = 10, 1, .1, .01, .001
MDI_HISTORY_FILE        = metric_mdi_history.txt
OPEN_FILE               = ""
EDITOR                  = leafpad
TOOL_EDITOR             = tooleditor x y
# required
USER_COMMAND_FILE       = plasmac_axis.py
# required
# for a working config add these to the [DISPLAY] section in your working configs ini file
EMBED_TAB_NAME          = Statistics
EMBED_TAB_COMMAND       = gladevcp -c plasmac_stats -x {XID} -u ./plasmac_stats.py -H ./plasmac_stats.hal plasmac_stats.glade
# use one of the next two
# run panel in tab behind preview
EMBED_TAB_NAME          = Plasma Run
EMBED_TAB_COMMAND       = gladevcp -c plasmac_run -x {XID} -u ./plasmac_run.py -H plasmac_run.hal plasmac_run_tab.glade
# run panel in panel on right side
#GLADEVCP                = -c plasmac_run -u ./plasmac_run.py -H plasmac_run.hal plasmac_run_panel.glade
EMBED_TAB_NAME          = Plasma Config
EMBED_TAB_COMMAND       = gladevcp -c plasmac_config -x {XID} -u ./plasmac_config.py -H plasmac_config.hal plasmac_config.glade
[EMC]
VERSION                 = 1.1
MACHINE                 = METRIC_PLASMAC
DEBUG                   = 0
[EMCIO]
EMCIO                   = io
CYCLE_TIME              = 0.100
TOOL_TABLE              = tool.tbl
[TASK]
TASK                    = milltask
CYCLE_TIME              = 0.01
[EMCMOT]
EMCMOT                  = motmod
BASE_PERIOD             = 32000
SERVO_PERIOD            = 1000000
[KINS]
KINEMATICS              = trivkins coordinates=xyyz
JOINTS                  = 4
[TRAJ]
SPINDLES                = 2
COORDINATES             = XYYZ
LINEAR_UNITS            = mm
MAX_LINEAR_VELOCITY     = 250
ANGULAR_UNITS           = degree
POSITION_FILE           = metric_position.txt
[AXIS_X]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
MAX_VELOCITY            = 250
MAX_ACCELERATION        = 2500
[JOINT_0]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
MAX_VELOCITY            = 250
TYPE                    = LINEAR
MIN_FERROR              = 0.025
FERROR                  = 1
HOME                    = 0.0
HOME_OFFSET             = 0.0
HOME_SEQUENCE           = 1
HOME_SEARCH_VEL         = 15
HOME_LATCH_VEL          = 1
HOME_FINAL_VEL          = 15
HOME_USE_INDEX          = NO
STEPGEN_MAXACCEL        = 3000
SCALE                   = -41.666667
STEPLEN                 = 1
STEPSPACE               = 0
DIRSETUP                = 8000
DIRHOLD                 = 5000
[AXIS_Y]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
MAX_VELOCITY            = 250
[JOINT_1]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
MAX_VELOCITY            = 250
TYPE                    = LINEAR
MIN_FERROR              = 0.025
FERROR                  = 1
HOME                    = 0.0
HOME_OFFSET             = 0.0
HOME_SEQUENCE           = -2
HOME_LATCH_VEL          = 1
HOME_FINAL_VEL          = 15
HOME_USE_INDEX          = NO
SCALE                   = 41.666667
STEPLEN                 = 1
STEPSPACE               = 0
DIRSETUP                = 8000
DIRHOLD                 = 5000
[JOINT_2]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
MAX_VELOCITY            = 250
TYPE                    = LINEAR
MIN_FERROR              = 0.025
FERROR                  = 1
HOME                    = 0.0
HOME_OFFSET             = 0.0
HOME_SEQUENCE           = -2
HOME_LATCH_VEL          = 1
HOME_FINAL_VEL          = 15
HOME_USE_INDEX          = NO
SCALE                   = 41.666667
STEPLEN                 = 1
STEPSPACE               = 0
DIRSETUP                = 8000
DIRHOLD                 = 5000
[AXIS_Z]
# this should be the top of your slats
MIN_LIMIT               = -0.001
MAX_LIMIT               = 70.001
# required, set to double the value in the corresponding joint
MAX_VELOCITY            = 120
MAX_ACCELERATION        = 1200
# required, shares the above two equally between the axis/joint and the offset
OFFSET_AV_RATIO         = 0.5
[JOINT_3]
MIN_LIMIT               = -0.001
MAX_LIMIT               = 70.001
MAX_VELOCITY            = 60
MAX_ACCELERATION        = 600
TYPE                    = LINEAR
MIN_FERROR              = 0.25
FERROR                  = 1.0
HOME                    = 65.0
HOME_OFFSET             = 70.0
HOME_SEQUENCE           = 0
HOME_LATCH_VEL          = 1
HOME_FINAL_VEL          = 15
HOME_USE_INDEX          = NO
STEPGEN_MAXACCEL        = 900.0
SCALE                   = 500.0
STEPLEN                 = 1
STEPSPACE               = 0
DIRSETUP                = 8000
DIRHOLD                 = 5000
22 Oct 2019 22:47 - 22 Oct 2019 22:56 #148564 by phillc54
Thanks, I see the problem here as well.
I'm not sure what is causing it but while I work on it if you want to try it out temporarily, use button #1 and it works ok, any other button and it doesn't.
Edit: I missed these in the sims, you need to change [AXIS_X] and [AXIS_Y] to:
MIN_LIMIT               = -0.001
MAX_LIMIT               = 612.001
# set to double the value in the corresponding joint
MAX_VELOCITY = 500.0
MAX_ACCELERATION = 5000.0
# shares the above two equally between the joint and the offset
Last edit: 22 Oct 2019 22:56 by phillc54.
  • LuisGZ
  • Junior Member
  • Junior Member
22 Oct 2019 23:04 #148565 by LuisGZ
That's right, in Axis I changed to button 1 and now it opens. Weird enough, when I open a program, run it, pause it and click on the button 1, it doesn't seems to do anything or show an error.
Alternatively, in Gmoccapy when paused it stays grayed out
22 Oct 2019 23:06 #148567 by phillc54
The Axis one won't do anything until you add the changes I put in the edit of the last post.
The following user(s) said Thank You: LuisGZ
  • LuisGZ
  • Junior Member
  • Junior Member
22 Oct 2019 23:09 - 22 Oct 2019 23:17 #148568 by LuisGZ
Right! Its working in the sim now, I'll add it aswell on Gmoccapy and check again
Edit: Gmoccapy still behaves as shown above
Last edit: 22 Oct 2019 23:17 by LuisGZ.
22 Oct 2019 23:56 #148572 by phillc54
I just pushed the fixes to Github, are you using Run In Place or Buildot?
  • LuisGZ
  • Junior Member
  • Junior Member
23 Oct 2019 01:25 - 23 Oct 2019 14:22 #148576 by LuisGZ
Great! I'm using a run in place installation, I will catch up tomorrow and test it out
Edit: I just updated my .ini with the PlasmaC Configurator and its all sorted out and working. Thanks!
Last edit: 23 Oct 2019 14:22 by LuisGZ.
Time to create page: 0.098 seconds
