How to update plasmaC
10 Oct 2019 12:23 #147632 by Clive S
How to update plasmaC was created by Clive S
Regarding this:-
An update pushed:
configurator typos in ini files
axis ini file typos
fix parameter saving bug
How do I know if I have a buildbot install or RIP
I have tried from a terminal sudo apt-get update then sudo apt-get upgrade
It did download some stuff successfully but did not change and fix the parameter saving bug.
Will it do any harm to upgrade using the RIP code
10 Oct 2019 16:31 #147643 by mkardasi
Replied by mkardasi on topic How to update plasmaC
RIP creates a ~/linuxcnc-dev directory if you followed the instructions verbatim. The command to start will contain "~/linuxcnc-dev/scripts/linuxcnc" buildbot pkg will usually run with "linuxcnc ~/linuxcnc/configs/........."
apt-get is for a build bot install & currently build bot is behind. So those changes will not be available in the latest dpkg.
No, you can just do a RIP installation to have the latest and greatest code & still keep the buildbot install as a back up should a future update to RIP break something. Just follow section 15.2 in the PlasmaC User Guide.
10 Oct 2019 17:18 #147644 by Clive S
Replied by Clive S on topic How to update plasmaC
Many thanks. for the informative reply :)
10 Oct 2019 23:26 #147667 by phillc54
Replied by phillc54 on topic How to update plasmaC
It appears that the Buildbot is taking a break. buildbot.linuxcnc.org/dists/
So if you want the latest you will need to do a RIP build or wait until the Buildbot returns from leave.
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
10 Oct 2019 23:40 #147668 by thefabricator03
Replied by thefabricator03 on topic How to update plasmaC
Phill,
What is the buildbot?
10 Oct 2019 23:53 - 10 Oct 2019 23:56 #147670 by phillc54
It is a continuous build system thats builds various branches of LinuxCNC from the latest commits on the github repo. It also builds documentation and updates the LinuxCNC website with that latest documentation.
EDIT: The builds are then available as packages that can be installed.
Some info here buildbot.linuxcnc.org/
Normally it will have completed a build within an hour or so of someone contributing an update but sometimes it decides to take a break.
Last edit: 10 Oct 2019 23:56 by phillc54.
The following user(s) said Thank You: Clive S, thefabricator03
11 Oct 2019 07:16 #147685 by phillc54
The Buildbot is up to date...
11 Oct 2019 12:09 #147696 by Clive S
Thanks Phill Updated now and parameters stick with save. :)
07 Dec 2019 15:05 #152258 by Clive S
Phill
I am having trouble updating . I have done:-
$ sudo apt-get update
$ sudo apt-get dist-upgrade
This ran OK and appeared to update. But I did not see the extra's tab (shapes etc) i
Then I tried;- $ python linuxcnc/<your_configuration_directory>/configurator.py
But I don't see the configurator.py in my linuxcnc config
Next I tried running the configurator.py from :- /usr/share
plasmac/confugurator.py ( see the configurator.py in plasmac ) but it errors
Should plasmac be running or stopped when upgrading? I also copied configurator.py to my config folder to no avail.
  • Moderator
  • Moderator
07 Dec 2019 20:36 #152286 by tommylight
Replied by tommylight on topic How to update plasmaC
Try
./configurator.py
from that same location.
Time to create page: 7.855 seconds
