Trying to sort out the THC with PlasmaC
- Clive S
- Thank you received: 486
31 Oct 2019 22:34 #149315
by Clive S
Silly me. I had looked through the ini file and did not notice it was missing. The ini file was generated by the 7i96 configurator .
For info the configurator also puts in metric instead of mm although linuxcnc using Axis works OK but not with PlasmaC as this needs it to be mm.
Thanks again Phill for the continued help you give.
Replied by Clive S on topic Trying to sort out the THC with PlasmaC
Yes, there should be a JOG_INCREMENTS setting in the [DISPLAY] section of the .ini file.
- phillc54
- Thank you received: 2100
31 Oct 2019 23:34 #149321
by phillc54
Replied by phillc54 on topic Trying to sort out the THC with PlasmaC
Thanks Clive,
Maybe you could let the author of that know, it also produces syntax that TWOPASS doesn't like:
should beI wrote a workaround for this in the Configurator but it should be fixed at the source
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1num_stepgens=4"sserial_port_0=1loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_stepgens=4 sserial_port_0=1"
Time to create page: 0.064 seconds
