Shape Library
  • Moderator
  • Moderator
06 Aug 2020 06:38 #177493 by tommylight
Replied by tommylight on topic Shape Library
0,0
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
06 Aug 2020 06:53 #177496 by phillc54
Replied by phillc54 on topic Shape Library
0,0
Thanks Tom, I did end up changing those leadin/leadout positions as well.
06 Aug 2020 09:25 #177511 by rodw
Replied by rodw on topic Shape Library
06 Aug 2020 09:26 #177512 by snowgoer540
Replied by snowgoer540 on topic Shape Library
0,0
x2
There's a bug in your math module...technically that's 3 :)
  • Moderator
  • Moderator
06 Aug 2020 09:29 #177513 by tommylight
0,0X2=0 ????
B)
  • phillc54
  • Platinum Member
  • Platinum Member
07 Aug 2020 00:33 #177577 by phillc54
  • Moderator
  • Moderator
22 Aug 2020 08:18 #178994 by tommylight
I really hope no one sees this...... :)
Phill, what are the chances of adding a square tube thingy to this ? Some details :
4 Axis machine with say X is the long one, Y is the short one, Z is the usual automatic THC thingy and A is the rotating one,
Since we use THCAD and that thing is fast and smooth, i would skip all the complicated math required and just have A axis move in 90 degree increments as that would simplify everything immensely, the only thing remaining to tackle would be at every A axis move of 90 Degree there would have to be added an Y axis move of the width of the square tube, say 80mm, and the THC would do it's job of following the up and down during that period. There is also the caveat that the feed rates of the A and Y axis would have to be tuned to move in sync so the torch does not loose position, but that is another topic altogether.
New thread, or delete and disappear ? :)
22 Aug 2020 08:32 #178995 by rodw
Sheetcam has a wrapped rotary module that basically treats the rotating part as if its a straight axis. I think you have to pay for it.
I think that if the Z axis has high enough acceleration and velocity, it should be able to follow the material up and down via THC control as it turns. I don't think there is any complicated maths required. Just let the THC do its job.
22 Aug 2020 08:35 #178996 by rodw
Oh and I forgot, this is a quite handy coping calculaotr which demonstrates what a wrapped rotary axis is. It creates a template you wrap around a tube to define the cut path. It works perfect if you need to notch a pipe.
www.metalgeek.com/static/cope.pcgi
  • Moderator
  • Moderator
22 Aug 2020 09:58 #179001 by tommylight
I am aware of that and i am not interested in it. I already have two rotary machines that cut round tubing using only Inkscape and LinuxCNC, one of them made all the cuts for an 82x36 meters border crossing "tent" or "hut" or whatever that is called, all made by round tubes and everything made on that machine ! :)
Yup, i did test that a few years back and i could cut up to 80x80mm with just two axis and THC. Was a bit tricky to set up but it did work as a test.
Time to create page: 0.810 seconds
