Plasmac Post Processors
- Thank you received: 7381
11 Sep 2025 17:58 #334836
Replied by tommylight on topic Plasmac Post Processors
There are no
N75 M3 $0 S1
in the gcode after the first piece, and no M5 at the end of the cut except for the first cut.
Those must be added by the post processor.
N75 M3 $0 S1
- mal136
13 Sep 2025 06:17 #334914
by mal136
Replied by mal136 on topic Plasmac Post Processors
IInteresting—I used the Fusion360 post processor from the first page of this thread (forum.linuxcnc.org/plasmac/38438-plasmac...t-processors?start=0). After rereading the PDF, it doesn’t explicitly say so, but I think I need to create separate 2D profiles for each feature I’m cutting. Since the post processor doesn’t generate Z movements, would that mean making individual profiles for all 12+ holes plus the part outline? and i assume plasmaC will control Z when it goes to probe for each cut? I also tried Inkscape (which I like), but it skips certain splines and rounded corners in my parts. Redesigning everything just to fit Inkscape’s gcode output would be counterproductive.
Thank you so much Tommylight for your reply, i greatly appreciate your help!
13 Sep 2025 16:04 - 13 Sep 2025 16:05 #334933
Sorry i can not help with Fusion, i use strictly Inkscape for all plasma machines, just use "prepare for plasma" and then export with the tool chosen as plasma.
Last edit: 13 Sep 2025 16:05 by tommylight.
