RTPREEMPT vs RTAI
- BeagleBrainz
- Visitor
31 Mar 2020 22:08 #162305
by BeagleBrainz
Replied by BeagleBrainz on topic RTPREEMPT vs RTAI
You can manually mark them
manpages.ubuntu.com/manpages/trusty/man8/apt-mark.8.html
- snowgoer540
- Thank you received: 900
31 Mar 2020 22:13 #162306
by snowgoer540
Thank you!
Any thoughts on the repositories?
Replied by snowgoer540 on topic RTPREEMPT vs RTAI
Thank you!
- BeagleBrainz
- Visitor
31 Mar 2020 22:25 - 31 Mar 2020 22:35 #162309
by BeagleBrainz
Remember this isn't windows.
But if you want you can keep an eye on the buildbot.
2.9 hasn't been marked as stable.
2.8 is still in discussion regarding a firm release date (hopefully soon).
2.7 is stable.
I haven't attempted to install any packages from the buildbot onto Mint 19.2 so I can't be sure if there is any issues regarding dependency versions.
Everthing kernel & linuxcnc related on the Mint ISOs has been built on Mint 19.2.
2.7 is stable.
Last edit: 31 Mar 2020 22:35 by BeagleBrainz.
- snowgoer540
31 Mar 2020 22:46 #162311
by snowgoer540
Definitely no misconceptions about this not being windows here... it's both the greatest and probably the worst thing about linuxcnc (because so many people are stuck on M$ teet).
At any rate, again I was just going by the PlasmaC documentation, and what it asks you to type in to get changes. I am admittedly mostly a n00b, so if not for the method in the user guide (which requires setting a repository), I've no idea how to update plasmac when Phill pushes an update. Hopefully that makes sense?
2.7 is stable.
- BeagleBrainz
- Visitor
31 Mar 2020 23:12 #162317
by BeagleBrainz
The Mint ISO's can be setup quite easily to pull in everything you need to build Linuxcnc from source. Read the release notes on the forum and the Linuxcnc docs and JT pages regarding building from source.
Everything is there to actually build your own packages or build a Run In Place install. If you can follow instructions you can build linuxcnc.
- Thank you received: 4648
01 Apr 2020 21:31 #162380
Replied by andypugh on topic RTPREEMPT vs RTAI
I am too lazy to read all the way back to find out what it being discussed here
But you can get preempt-rt updates from the buildbot as a repository
buildbot.linuxcnc.org
(has a web page with instructions)
However _no_ repository is currently building LinuxCNC images for RTAI and 4.xx.xx kernels.
So, if you are running the shiny new RTAI and want the very latest stuff, you will need to roll your own.
It's not that bad. Run-in-place takes about 10 mins.
- snowgoer540
01 Apr 2020 22:21 #162390
by snowgoer540
Thanks Andy.
That's exactly what I want to do... That way I can just do the updates like Phill suggests in the PlasmaC user guide (sudo apt-get update and sudo apt-get dist-upgrade).
The problem is I dont know what distro I have, or rather what distro Rob compiled from. As near as I can tell, I have Precise, Wheezy, Jessie, Stretch, and Buster to choose from. And I really have no idea how to tell which one I have... ?
Thanks Andy.
- phillc54
- Thank you received: 2100
01 Apr 2020 22:57 #162397
by phillc54
Replied by phillc54 on topic RTPREEMPT vs RTAI
You would need to follow the Run In Place instructions in sect 19.2 linuxcnc.org/docs/devel/html/plasma/plas...nuxcnc_configuration. In this case the distro doesn't matter.That's exactly what I want to do... That way I can just do the updates like Phill suggests in the PlasmaC user guide (sudo apt-get update and sudo apt-get dist-upgrade).
- BeagleBrainz
- Visitor
01 Apr 2020 23:56 #162411
by BeagleBrainz
Everything has been compiled on Mint 19.2 which is bionic, which can be found be looking at your apt sources.
When you run apt-get update you can see which repos are being used.
But I'm thinking until I can get the installation issues worked out when booting from UEFI I'm going to disable all links for the ISOs
02 Apr 2020 19:59 #162487
Try this command from the terminal:
cat /etc/os-release
cat /etc/os-release
Time to create page: 1.448 seconds
