Probe Test
- little_sparky
- Thank you received: 17
07 Apr 2020 07:36 #163048
by little_sparky
Probe Test was created by little_sparky
Hi All,
after almost 2 years I can finally see the home straight! Cant thank you all enough.
One thing I have a small question about is the probe test.
When I click the probe test button, it goes down until it touches the top of the material and when it triggers the float switch it immediately stops and an error message comes up saying float switch detected while moving to probe height.
I thought this would be right, except I thought it is meant to retract to the pierce height ready to cut.
I am not sure if I am on the completely wrong tram here or if this is normal or what the go is.
Thank you in advance.
- phillc54
- Thank you received: 2100
07 Apr 2020 07:40 #163049
by phillc54
Replied by phillc54 on topic Probe Test
Normally that would mean you have the Probe Height set too low.
Probe Height is measured from the Z Minimum Limit.
It should move down at Setup Speed until it reaches Probe Height then it moves at Probe Speed until it reaches the material.
- little_sparky
07 Apr 2020 07:43 #163050
by little_sparky
Replied by little_sparky on topic Probe Test
i thought this was the case, but then when I set the probe height higher, it would just come down to the new height (say 20mm above material), stop, wait for the 10 seconds and then retract back up to a random height where it started.
- phillc54
07 Apr 2020 07:53 #163052
by phillc54
Check the ini file for the button code that does the probe height and make sure it is:
BUTTON_n_CODE = probe-test 30Please Log in or Create an account to join the conversation.
- little_sparky
07 Apr 2020 07:54 #163053
by little_sparky
okay will do, i have this set to 10 currently, does it not work at 10?
Ill go change this and get back to you. Thank you
- phillc54
07 Apr 2020 07:56 #163054
by phillc54
It should, that means it will wait 10 seconds at Pierce Height.
- little_sparky
07 Apr 2020 08:02 #163056
by little_sparky
- little_sparky
07 Apr 2020 08:04 #163058
by little_sparky
I changed probe-test 10 to probe-test 30 and still the same thing.
- little_sparky
07 Apr 2020 08:10 #163059
by little_sparky
Okay I think I worked it out! My probe speed must have been too low
- little_sparky
07 Apr 2020 08:11 #163060
by little_sparky
I also unchecked the “ohmic probe enable” box in the plasma run screen
Time to create page: 0.146 seconds
