Hypersensing questions
6 years 5 months ago #166985 by Uthayne
Replied by Uthayne on topic Hypersensing questions
I did a small job yesterday on 1/4" steel. About 100 pierces and not a signal problem. My probe speed is set at 30 ipm, and I did notice a slight overrun of about 1/16" in my float switch when probing. My float switch has about 1/8" of travel before it triggers, so it was more than enough. I haven't maxed out my ohmic probe speed yet, 30 ipm seemed reasonable.
However all of this isn't really an issue seeing that the height is set when the contact is broken, so as long as there is enough travel in the float switch, a little bit of overrun is fine.
6 years 5 months ago #166987 by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
I agree, I had to slow my probe down to about the same speed to prevent overrun. Unfortunately my float switch trips at about .025". So I may have made the float switch TOO efficient. At any rate, after slowing it down, all was well.
6 years 4 months ago - 6 years 4 months ago #172653 by snowgoer540
rodw wrote:
Note the component is now named ohmic2.comp
you need to halcompile --install ohmic2.comp (non source code guys will need ot use sudo and you may need to install the linux_dev stuff. I'm not really up with deb installs.
I helped someone install ohmic2.comp on their buildbot install of 2.8. Halcompile does not appear to be part of that, but here is how to install it and then install the component for those who go looking later:
sudo apt-get install linuxcnc-uspace-dev sudo halcompile --install ohmic2.comp
Of course, you need to run the second line from the directory you have the ohmic2.comp file located.
Last edit: 6 years 4 months ago by snowgoer540.
6 years 4 months ago - 6 years 4 months ago #172654 by snowgoer540
Brings me to two more thoughts:
1. When will ohmic component make the plasmac user guide (with diagrams, etc), and/or be part of PlasmaC? I know the old ohmic.comp is part of 2.9 branch, but now that 2.8 is recommended, what's the plan there?
2. Is there a convenient place we can put plasmac related "extra" files for easy grabs? For example: the Plasma versions of the 7i76e, 5i25_7i76, and 7i96 mesa firmware, and if the ohmic component isnt going to be standard with PlasmaC or Linuxcnc, then the component file as well. I'm not sure if there is anything else I cant remember at the moment.
I had to go digging this evening, and just thought it would be nice if it was all in one place. I'm happy to gather up the files if someone would like to make a pinned thread?
6 years 4 months ago #172657 by phillc54
Replied by phillc54 on topic Hypersensing questions
The ohmic comp is separate to PlasmaC and is one way to do ohmic sensing.
It is vailable in 2.8 github.com/LinuxCNC/linuxcnc/blob/2.8/sr...omponents/ohmic.comp .
I could add a bit of a blurb to the PlasmaC user guide in the appendix.
6 years 4 months ago #172659 by snowgoer540
phillc54 wrote: The ohmic comp is separate to PlasmaC and is one way to do ohmic sensing.
True, I didn’t think of that but it is similar to how THCAD is one way for voltage sensing and THC. I will say it seems to work well though.
Didn’t realize that about 2.8. So that begs the question when will ohmic 2 become ohmic lol.
I think it’s probably a good idea. Just was thinking of the new people, and how many questions I had (and still have).
Time to create page: 0.169 seconds
