THC will not Enable
- santy
- Thank you received: 10
18 Apr 2023 23:58 #269391
by santy
hello, i am having this exact problem with the recent master version of linuxcnc. the voltage appears, i have it enabled, i get arc ok with mode 0 no problem, i can even override arc OK, but thc will not enable.
do you have any idea about what could be missing here?
thank you
Replied by santy on topic THC will not Enable
I have pushed the fix.
thank you
- phillc54
- Thank you received: 2100
19 Apr 2023 00:12 - 19 Apr 2023 00:13 #269392
by phillc54
Replied by phillc54 on topic THC will not Enable
This thread is for PlasmaC, if you are using master branch then you must be using QtPlasmaC.
Can you post a copy of the BACKUP CONFIG from the SETTINGS tab.
EDIT:
Is THC enabled?
Is the velocity during the cut reaching the same as what the material cut speed specifies?
EDIT:
Is THC enabled?
Last edit: 19 Apr 2023 00:13 by phillc54.
Time to create page: 0.196 seconds
