phillc54 wrote: Check Arc Fail Timeout in the Config Panel
linuxcnc.org/docs/2.8/html/plasma/plasma...de.html#config-panel
THC Delay works identically for all modes.
EDIT: Set Arc OK High really high until you tune it in.
rodw wrote: Just remember that if your plasma cutter decides the arc is lost, its going to cut the arc regardless of any synthesised arcOK signal. NOt using your ArcOK signal is just adding one more potential failure point.
Its possible any relay you've used on your ArcOK circuit could be responsible for most of the latency. I've wired mine direct to a Mesa Input.
You could compensate for latency in ArcOK by reducing pierce dealy.
