Display problem plasmac V.0.124
- Clive S
- Thank you received: 486
14 May 2020 14:15 #167745
by Clive S
Replied by Clive S on topic Display problem plasmac V.0.124
Yes I believe so - setp plasmac.multi-tool 1 Would this be why $2 does not turn the torch on?Do you have multitool enabled in your connections Hal file?
- phillc54
- Thank you received: 2100
14 May 2020 23:26 - 15 May 2020 01:02 #167794
by phillc54
Replied by phillc54 on topic Display problem plasmac V.0.124
It needs to be 1 to allow $2 to work so you have it set correctly.
EDIT: Have set the Spotting Threshold and Delay in the Congig Panel?
If your image doesn't quite fit you could revert to LinuxCNC 2.8, it doesn't have the active g-codes on the main screen, they are in the MDI tab.
I forgot to mention that you cannot use MDI while paused, the interpreter needs to be in idle mode.
Last edit: 15 May 2020 01:02 by phillc54. Reason: a question
- phillc54
14 May 2020 23:29 #167795
by phillc54
A bit different in Chrome but I get the idea. Neat trick Tom.
Forum, right click on image, view image info on the context menu.Thanks Tom, where did that pic come from?
