plasmac install error
30 May 2020 00:09 #169366 by Nate
plasmac install error was created by Nate
here is a screen shot of my trying to install the plasmac config can someone help me on why i cant
30 May 2020 00:13 #169367 by rodw
Replied by rodw on topic plasmac install error
Check the file exists where you think it does.
30 May 2020 00:18 #169368 by Nate
Replied by Nate on topic plasmac install error
I am new to all this how do I do that
30 May 2020 00:32 #169370 by rodw
Use the file browser and navigate the folder structure looking for configurator.py
I use a run in place (compile from source) config so my files are in a different place.
You should be able to double click on it to run it when you find it with luck!
30 May 2020 00:33 #169371 by rodw
Hang on, you have an extra $ sign at the beginning of the command line. Remove that and it should work...
15 Jun 2020 19:25 #171763 by Nate
good afternoon anyone know why i am getting this error after running the plasmac config
15 Jun 2020 19:50 - 15 Jun 2020 19:51 #171764 by tommylight
Replied by tommylight on topic plasmac install error
You have the same coolant pin connected twice in one of the hal files, and that brings the question: why do you have coolant set for plasma ?
Edit:
Just delete the line with coolant mist in the plasmac_connections.hal file.
Last edit: 15 Jun 2020 19:51 by tommylight. Reason: More info
15 Jun 2020 20:02 #171766 by Nate
i was just using coolant to turn the torch on and off i am not actually using any coolant pumps
15 Jun 2020 20:12 #171769 by Nate
for some reason if i used it a spindle then the torch would not start
15 Jun 2020 21:04 #171770 by Nate
now i have the machine moving. i am getting ark ok but no up and down movement when putting the proma thc in test mode also i am not getting the z to move up and down using the float switch before a cut
Time to create page: 0.261 seconds
