plasmac install error
- Nate
15 Jun 2020 21:05 #171771
by Nate
Replied by Nate on topic plasmac install error
do i have to have z limit switches installed because all i have on the z is the float switch
- Thank you received: 7485
15 Jun 2020 22:32 #171779
Replied by tommylight on topic plasmac install error
Not really, it will work without them, granted you did not set them in the original machine config.
- Nate
15 Jun 2020 22:42 #171781
by Nate
no i did not my 7i96 is showing the up and down movement with the led lights from the thc but the on screen is not showing the up and down but it is showing the ark okay also how to i get it to test the float switch i told it to cut a sample file and the z never moved
15 Jun 2020 22:46 #171782
Compress the config folder and attach it here, also some screenshot occasionally and a picture of the wiring would help.
To test the float switch just move it by hand while looking at the float LED on screen.
- Nate
15 Jun 2020 23:12 #171784
by Nate
as for the z float switch it dose not change on the screen by moving it up and down with my hand but i can get it to blink if i run it down with jog here is a copy of my hal and ini files as for how by board is wired
inputs
00-03 is y limits
4-5 x limits
06 float switch
07 estop
08 thc up
09 thc down
10 thc ark okay
outputs
00 torch fire relay
inputs
00-03 is y limits
4-5 x limits
06 float switch
07 estop
08 thc up
09 thc down
10 thc ark okay
outputs
00 torch fire relay
- phillc54
- Thank you received: 2100
16 Jun 2020 02:44 - 16 Jun 2020 02:47 #171811
by phillc54
Replied by phillc54 on topic plasmac install error
Are you homing your machine before operating it?
Could you compress the complete Nathan_Plasma2 directory and post it.
EDIT: You also would be better off posting in the PlasmaC section of the forum for PlasmaC specific topics. forum.linuxcnc.org/plasmac
Last edit: 16 Jun 2020 02:47 by phillc54.
16 Jun 2020 12:07 #171840
Moved.Are you homing your machine before operating it?
Time to create page: 0.121 seconds
