Plasmac Configurator
07 Jun 2020 17:21 #170536 by KaleD
Plasmac Configurator was created by KaleD
I am trying to set up ohmic probing for my plasma machine. When I assign pins in the Configurator some are not saved. The Torch On, Ohmic Probe and Ohmic probe enable Hal pins do not appear anywhere in the Hal files and are also gone when I try to reconfigure.
The other pins show up in the <>connections.hal. I'm not sure what file the Ohmic stuff should be in. I have followed the same syntax as the other pins(parport.0.pin-#-in).
I have a pretty simple setup of a Chinese parallel port BOB and TB6600s. I'm using Plasmac with the Gmoccapy GUI. I'm using the up-down THC option. All I am aiming for is the ability probe before each cut.
File Name: working_co...6-07.hal
File Size:1 KB
File Name: working_config.hal
File Size:3 KB
Thanks,
07 Jun 2020 17:29 #170539 by KaleD
Replied by KaleD on topic Plasmac Configurator
Also, I'm using 2.8
07 Jun 2020 19:00 #170547 by phillc54
Replied by phillc54 on topic Plasmac Configurator
All the optional connections except for the powermax should appear in working_config_connections.hal
I just tried a sample with 2.8 and it works fine here.
  • Moderator
  • Moderator
07 Jun 2020 19:05 #170548 by tommylight
Replied by tommylight on topic Plasmac Configurator
Are you sure you are using the right ini file to modify and not the original plain machine one ?
The following user(s) said Thank You: phillc54, KaleD
07 Jun 2020 19:20 #170552 by KaleD
I should be using working_config_connections.hal and not the original_working_config_connections.hal, correct?
07 Jun 2020 19:24 - 07 Jun 2020 19:24 #170553 by phillc54
There shouldn't be a original_working_config_connections.hal.
When you first use Configurator to make a machine it should be a different name to the original base machine then it will create the files it needs and make a backup copy of your original base machine ini and hal file. From then on you work with the files that were created by Configurator in the new <machine-name> directory.
Last edit: 07 Jun 2020 19:24 by phillc54.
07 Jun 2020 19:37 #170554 by KaleD
These are all the files I ended up with. I assumed that all the original ones where backups of just the stepconf info. I haven't been touching the originals.
07 Jun 2020 19:46 #170555 by phillc54
That all looks correct and yes the _original... are just backups of your base machine.
07 Jun 2020 19:56 #170556 by KaleD
I was able to get the pins assigned as I desire. I'm getting an error:
Should I start a new thread? I don't have anything plugged in for probes yet.
07 Jun 2020 19:57 #170557 by phillc54
Is your probe LED on all the time, if not does it come on when you do an ohmic test.
Time to create page: 0.330 seconds
