Plasmac Configurator
- KaleD
- Thank you received: 7
08 Jun 2020 01:10 #170558
by KaleD
Replied by KaleD on topic Plasmac Configurator
- phillc54
- Thank you received: 2100
08 Jun 2020 01:28 #170560
by phillc54
Replied by phillc54 on topic Plasmac Configurator
Yes, yellow shows the LED as on. You need to connect the ohmic probe to in-not rather than in.
See 1.2 here linuxcnc.org/docs/2.4/html/hal_parallel_port.html
oops, I forgot to hit Submit....
- KaleD
08 Jun 2020 01:40 #170562
by KaleD
The error is gone. Thank you. Now I can't get the probe to trip. is 5v into P15 enough juice? The enable is actuating a relay just like I planned.
- phillc54
08 Jun 2020 01:42 #170563
by phillc54
I "think" with parports you need to pull them down to 0V.
Someone who knows more about that than me may chime in...
- KaleD
08 Jun 2020 01:56 #170566
by KaleD
In that event the ohmic sensor should trip when hooked to ground. Correct?
- phillc54
08 Jun 2020 02:10 #170568
by phillc54
Yep.
- KaleD
08 Jun 2020 02:13 #170569
by KaleD
non of the grounds on the BOB affect it.
- phillc54
08 Jun 2020 02:17 #170571
by phillc54
You may need to run HalShow so you can check the parport pins. If you use Watch on the required pins you will be ble to see them activate.
linuxcnc.org/docs/html/hal/halshow.html
- KaleD
08 Jun 2020 02:27 #170572
by KaleD
I'm looking at plasmac.ohmic-probe and also parport.0.pin-15-in-not.
both of them are red no matter what.
- phillc54
08 Jun 2020 02:49 #170574
by phillc54
So the parport is not seeing the signal. Are you using a ground signal from the parport?
Time to create page: 0.157 seconds
