Plasmac Configurator
- KaleD
- Thank you received: 7
08 Jun 2020 03:25 #170577
by KaleD
Replied by KaleD on topic Plasmac Configurator
yes.Are you using a ground signal from the parport?
- phillc54
- Thank you received: 2100
08 Jun 2020 07:21 #170588
by phillc54
Replied by phillc54 on topic Plasmac Configurator
Sorry I missed your last post.
Try Halshow with other parport inputs, it may be a faulty input.
Are you directly grounding the pin in the parport or via the BOB. Also I think some BOB ground is not the same as parport ground.
I thought we might get other folk posting but nothing yet...
The following user(s) said Thank You: KaleD
- Clive S
- Thank you received: 486
08 Jun 2020 07:57 #170591
by Clive S
Replied by Clive S on topic Plasmac Configurator
OK A pic of the PPort bob might help the cheap Chinese one's require 12-24V as well as the 5v in order for the inputs to work
- KaleD
08 Jun 2020 14:09 #170646
by KaleD
feeding 12v to the board seems to have done the trick. I only had the 5v power source hooked up until now. As far as I can tell right now it is working. Thanks Clive.
I can't thank you enough for your help Phill. Plasmac is awesome.
Time to create page: 0.083 seconds
