Float Switch Activated
6 years 4 months ago #171807 by phillc54
Replied by phillc54 on topic Float Switch Activated
little_sparky wrote: Yep, and the Z axis is moving.
I have the height per volt set pretty low, what value should this be?
Unless you have done some halscope plots and measured it then leave it at the default 0.1mm (0.004") which should be in the ballpark.
The following user(s) said Thank You: little_sparky
