Probe or Arc problem
- KaleD
- Thank you received: 7
24 Jun 2020 03:06 #172529
by KaleD
Probe or Arc problem was created by KaleD
At the start of every cut my machine probes down, finds the work piece then fires but moves nowhere. Or it moves down and does not fire at all and also does not work. It doesn't show any errors. And sometimes it does fire and move. The arc ok led is on. I'm not sure what is causing the issue.
- phillc54
- Thank you received: 2100
24 Jun 2020 04:43 - 24 Jun 2020 05:43 #172533
by phillc54
Replied by phillc54 on topic Probe or Arc problem
comment out this line in plasmatable.halPlasmaC does not use the spindle.n.at-speed pins.
You could get rid of all the spindle stuff if you wanted.
EDIT: You also have conflicting MAX_VELOCITY and MAX_ACCELERATION values in plasmatable.ini. If the values in [JOINT_0], [JOINT_1] and [JOINT_2] are correct then you need to change your corresponding [AXIS_n] values to:
I pushed a fix so Configurator will now comment out spindle.0. lines.
net spindle-at-speed => spindle.0.at-speedYou could get rid of all the spindle stuff if you wanted.
[AXIS_X]
# set to double the value in the corresponding joint
MAX_VELOCITY = 2.0
MAX_ACCELERATION = 50.0
[AXIS_Y]
MAX_VELOCITY = 10.6
[AXIS_Z]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 50.0I pushed a fix so Configurator will now comment out spindle.0. lines.
Last edit: 24 Jun 2020 05:43 by phillc54.
The following user(s) said Thank You: KaleD
