Using Powermax with RS485
24 Jun 2020 08:37 #172541 by Clive S
Using Powermax with RS485 was created by Clive S
Re this from the manual :-
A typical connection diagram is shown in the appendix of this document.
It should be noted that during the initial testing phase of this feature it was found that the USB to RS485 converter had reliability issues and that a PCI RS485 card was then installed on the test machine with no issues at all.
Has anybody successfully done this without a pci card?
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
24 Jun 2020 08:46 #172543 by thefabricator03
Replied by thefabricator03 on topic Using Powermax with RS485
I could not get the USB to rs485 converter to work but you might have better luck.
24 Jun 2020 08:49 #172544 by phillc54
Replied by phillc54 on topic Using Powermax with RS485
All my testing was done with a USB to RS485 converter BUT I wasn't testing with a Powermax, just an Arduino.
24 Jun 2020 08:55 #172545 by Clive S
Replied by Clive S on topic Using Powermax with RS485
Phill can the communications be tested without firing the torch up and without air. ie just with the machine powered up
24 Jun 2020 08:57 #172546 by phillc54
Yes, there is a little test program included called pmx_test.py
24 Jun 2020 09:01 #172547 by snowgoer540
Replied by snowgoer540 on topic Using Powermax with RS485
Yes, I used the serial port on the motherboard. It did require using a rs232 to rs485 adapter still.
29 Jun 2020 07:38 #173059 by Clive S
I don't see the connections in the manual
just this:-
30.3. RS485 Connections
width=75%
29 Jun 2020 07:46 #173060 by rodw
Replied by rodw on topic Using Powermax with RS485
Clive,
Check the docs for V 2.8 as master branch docs do not display images. Try this
linuxcnc.org/docs/2.8/html/plasma/plasma...ml#rs485_connections
Snowgoer, There are some single board computers that have a RS485 built in. The Odroid H2+ has a UART built into the GPIO pins and they suggest using a MAX RS485 chip to connect to the UART. I suspect the seedstudio does the same
I have ordered an odroid so it will be interesting to see how I go.
29 Jun 2020 09:04 #173063 by Clive S
Clive,
So are you saying that then manual from this link linuxcnc.org/docs/devel/html/plasma/plas...ml#rs485_connections is pointing to the 2.9 branch. Surely it should point to the 2.8 branch
29 Jun 2020 09:07 #173064 by phillc54
The "devel" in that link means development branch (2.9) for 2.8 it would say "2.8" instead.
Time to create page: 0.177 seconds
