Using Powermax with RS485
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
29 Jun 2020 09:17 #173065 by rodw
Replied by rodw on topic Using Powermax with RS485
I have found its not enough to use google to find a link. You always need to got to linuxcnc.org and follow through to the docs so you get the right info.
Its annoying that master branch does not get the images.
29 Jun 2020 09:31 #173066 by phillc54
Replied by phillc54 on topic Using Powermax with RS485
Yes, you need to make sure you are using the docs relevant to the version you are running.
Thats the risk you take using master. :)
29 Jun 2020 09:55 #173067 by Clive S
Replied by Clive S on topic Using Powermax with RS485
Phill. I am going this route. From linuxcnc forum.linuxcnc.org/plasmac/37234-plasmac-documentation#143121
then looking at section 30.3
I am using 2.8.
29 Jun 2020 10:06 #173068 by phillc54
OK, if you use the link to LinucCNC 2.8 it works.
I will remove the link to the PlasmaC docs on master.
29 Jun 2020 10:09 #173069 by Clive S
Yes thanks Phil I know that the two are different but it is confusing when the manual docs point to the wrong place.
29 Jun 2020 10:10 #173070 by phillc54
Fixed
29 Jun 2020 10:12 #173071 by Clive S
Fixed
That was quick and it works correctly now, Thanks
29 Jun 2020 10:16 #173072 by phillc54
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
29 Jun 2020 11:44 #173074 by rodw
Personally, I think thats bullshit. Its actually a consequence of the dev team not rolling out 2.8 to replace V 2.7 in a timely fashion once they branched it off the master branch. 2.7, 2.8 and 2.9 (master) should have only existed side by side for a matter of weeks, not years and years. Heck guys, I've never used the stable branch (2.7 when I started) becasue it never supported what I wanted. I;ve always used master, why would I change?
I checked out some forum datestamps and saw that I was sharing components for 2.8 on this forum over three years ago. Now we have a situation where some enhancements to master are being rolled back to V 2.8. Its really piss poor in my view and is holding the project back.
Yes I know, people will say open source, no warranty blah, blah, blah but really we are custodians of a brand and its up to us all to keep that brand moving forward. What we've done over the last couple of years has really hurt the brand.
Please fix it!
29 Jun 2020 11:55 #173075 by phillc54
As you well know, master is the development branch and is liable to be broken from time to time. Released branches are irrelevant to that.
Time to create page: 0.706 seconds
