HAL Question
- snowgoer540
- Thank you received: 907
01 Jul 2020 22:02 #173347
by snowgoer540
HAL Question was created by snowgoer540
Trying to get my ohmic power supply on a SSR that I have in my cabinet. I want to hook it to output-01 of my 7i76... I borrowed the ohmic stuff from Rod's Spaceship HAL file, and thought it was as easy as changing his output to fit my board.
IE:
However, the Hardware Abstraction Layer is something, despite Reading the Fing Manual, that remains... abstract to me.
I'm sure it's simple, but I can't see it. At any rate, I've attached my files. The ohmic stuff is in the plasma_connections.hal, but I attached the rest for good measure.
Thanks as always.
IE:
net ohmic:power => hm2_7i76e.0.7i76.0.0.output-11
to
net ohmic:power => hm2_5i25.0.7i76.0.0.output-01However, the Hardware Abstraction Layer is something, despite Reading the Fing Manual, that remains... abstract to me.
Thanks as always.
- Thank you received: 5335
01 Jul 2020 22:13 #173348
Replied by PCW on topic HAL Question
That looks correct
What is the issue?
What is the issue?
- snowgoer540
01 Jul 2020 22:14 #173349
by snowgoer540
It doesnt do anything, neither when I click ohmic test, nor probe test with ohmic enabled.
I even watched in the HAL Watch, and the output never changes states.
Replied by snowgoer540 on topic HAL Question
That looks correct
What is the issue?
01 Jul 2020 22:19 #173350
does ohmic:power change?
- snowgoer540
01 Jul 2020 22:22 #173351
by snowgoer540
it does not
it does not
01 Jul 2020 22:26 #173352
OK so that's a Plasmac question
- snowgoer540
01 Jul 2020 22:31 #173353
by snowgoer540
Copy that, thanks PeterOK so that's a Plasmac question
01 Jul 2020 22:34 #173354
It might still be a HAL question, ( some input not working/connected righht etc )
but I don't know what plasmac needs to assert ohmic:power
- snowgoer540
01 Jul 2020 22:36 #173355
by snowgoer540
In all honesty it could be something unique to rod’s table...
- phillc54
- Thank you received: 2100
01 Jul 2020 22:44 #173356
by phillc54
Replied by phillc54 on topic HAL Question
I think that is all part of the ohmic component.
This line:connects the plasmac.ohmic-enable output pin to the ohmic component. This pin should go True when you do an ohmic test. From there the ohmic component handles everything.
This line:
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probingPlease Log in or Create an account to join the conversation.
