HAL Question
- Thank you received: 4150
03 Jul 2020 22:01 #173557
Replied by rodw on topic HAL Question
I tried heaps of options to get it to turn on until I did that with motion-type.
The space should not make any difference except to pedantic code reviewers.
So if you want to test if the torch is shorted which is what I think you really want to do, you could use the or2 component so that power-on or the plasmac test button turn the relay.
You should know enough about hal by now to do that yourself
- snowgoer540
- Thank you received: 907
03 Jul 2020 22:19 #173561
by snowgoer540
My attention to detail knows no bounds
... except when I miss the obvious haha
You give me more credit than I deserve, but I’ll dork around with it and try to figure it out, there has to be an example out there I can plagiarize shamelessly!
Replied by snowgoer540 on topic HAL Question
- snowgoer540
03 Jul 2020 23:05 - 03 Jul 2020 23:06 #173565
by snowgoer540
As it turns out, maybe I don't give myself enough credit...And it works like I'd expect!
There's one thing I dont quite get with regard to HAL, why dont these follow the net <signal> <source> => <destination> convention:
loadrt or2
addf or2.0 servo-thread
net plasmac:ohmic-enable => or2.0.in0
net ohmic:power => or2.0.in1
net or-out or2.0.out => hm2_5i25.0.7i76.0.0.output-01There's one thing I dont quite get with regard to HAL, why dont these follow the net <signal> <source> => <destination> convention:
net ohmic:power <= ohmicsense.power-on
net ohmic:power => hm2_5i25.0.7i76.0.0.output-01
Last edit: 03 Jul 2020 23:06 by snowgoer540.
- phillc54
- Thank you received: 2100
03 Jul 2020 23:31 #173566
by phillc54
Replied by phillc54 on topic HAL Question
Unfortunately there is no convention, folk do it the way that suits them.
The => and <= are not required, they are only used to make it (supposedly) easily human readable.
- snowgoer540
03 Jul 2020 23:50 #173567
by snowgoer540
Yea, but I guess what I'm asking, is the other ones had 3 things. For example:or is Rod just breaking it up ? Meaning, would the following do the same thing:
Just trying to wrap my head around this... starting to make sense, but just enough to get the thing to error out and complain to me until I get it right.
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probingnet plasmac:ohmic-enable <= plasmac.ohmic-enable
net plasmac:ohmic-enable => ohmicsense.is-probingJust trying to wrap my head around this... starting to make sense, but just enough to get the thing to error out and complain to me until I get it right.
- phillc54
03 Jul 2020 23:51 #173568
by phillc54
Yes, they both give the same result.
- snowgoer540
03 Jul 2020 23:56 #173569
by snowgoer540
AH! Well, I feel I've made it much further to understanding how this all works lol.
Many thanks to everyone, as always.
04 Jul 2020 02:11 #173576
Great work. I just break it up because when I come back to it later and want to use the same signal I find it's there. Other times I have had to change some statements to expose what I want.
Time to create page: 0.729 seconds
