Materialverter
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
06 Jul 2020 17:26 - 06 Jul 2020 17:36 #173776 by snowgoer540
Materialverter was created by snowgoer540
Used the materialverter for the first time today, from Sheetcam. Everything worked great, except for one small detail, I had the Cut Mode set as 2 for all of my materials, and it didn't pick that up, they were all at Cut Mode = 1 after the conversion. So, I proposed the fix on github. Yep, you read that correctly. I'm officially contributing to the code, no longer just finding problems... I'm proposing solutions :). :woohoo:
Just in case you want any code to test the fix (it works on my end)...
Input Example:
[Tool0]
Type=PlasmaTool
Name=65A Steel 10GA Best
Comment=
Tool\ number=1
Kerf\ width=1.651
Plunge\ rate=0
Pierce\ delay=0.1
Pause\ at\ end\ of\ cut=0
Wiggle\ length=9.999979999999999
Pierce\ height=3.81
Cut\ height=1.524
Pierce\ type=0
Feed\ rate=4826
Lead\ in=0
Lead\ out=0
Lead\ in\ type=0
Lead\ out\ type=0
CodeSnip=-1
Hole\ Size=0
Use\ leadin\ settings=0
[Tool0/Custom]
Puddle\ jump\ height=0
Puddle\ jump\ delay=0
THC\ enable=1
Cut\ voltage=125
Cut\ current=65
Gas\ pressure=0
Cut\ mode=2
Output Example (before fix):
[MATERIAL_NUMBER_1]
NAME               = 65A Steel 10GA Best
KERF_WIDTH         = 0.065
THC                = 1
PIERCE_HEIGHT      = 0.150
PIERCE_DELAY       = 0.1
PUDDLE_JUMP_HEIGHT = 0
PUDDLE_JUMP_DELAY  = 0
CUT_HEIGHT         = 0.060
CUT_SPEED          = 190
CUT_AMPS           = 65
CUT_VOLTS          = 125
PAUSE_AT_END       = 0
GAS_PRESSURE       = 0
CUT_MODE           = 1
Output Example (after fix):
[MATERIAL_NUMBER_1]
KERF_WIDTH         = 0.065
THC                = 1
PIERCE_DELAY       = 0.1
CUT_HEIGHT         = 0.060
CUT_SPEED          = 190
CUT_AMPS           = 65
CUT_VOLTS          = 125
PAUSE_AT_END       = 0
GAS_PRESSURE       = 0
CUT_MODE           = 2
First HAL, now Github changes... wonder what's next!? B)
EDIT: I am 99% sure I proposed the changes correctly on github. If I didnt, and I need to do it some other way, please let me know. Also, if you prefer I suggest changes here instead, let me know that as well.
Last edit: 06 Jul 2020 17:36 by snowgoer540.
The following user(s) said Thank You: dvn4life1972
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
06 Jul 2020 17:30 #173777 by thefabricator03
Replied by thefabricator03 on topic Materialverter
You need to stop that, your making the rest of us look bad ;)
  • snowgoer540
  • Moderator
  • Moderator
06 Jul 2020 17:31 #173778 by snowgoer540
Replied by snowgoer540 on topic Materialverter
Haha, well hopefully it's not a 1 hit wonder.
06 Jul 2020 18:58 #173784 by phillc54
Replied by phillc54 on topic Materialverter
Thanks for that, something else I missed.
A couple of additions are required to bring the version number up to date:
in the same directory:
plasmac_config.py - line 324 - new version and date
version.html - line 22 - create a new version and date block
in linuxcnc-dev/src/hal/components:
plasmac.comp - line 10 - new version and date
Maybe I should put a sticky thread describing this in case others want to contribute code.
  • snowgoer540
  • Moderator
  • Moderator
06 Jul 2020 19:14 #173786 by snowgoer540
Well, on the bright side, something you dont have to spend time fixing :) In all reality, I just plagiarized what was there, and changed variable names. I couldnt write that code outright.
Ok, other than the additions to the files, did I do everything else correctly? Am I supposed to start a pull request to linuxcnc? I'm a bitt miffed about how it actually gets into the next update...
Do you want me to make the aforementioned changes to the other 3 files?
06 Jul 2020 19:22 #173788 by phillc54
Well you found where the problem was and that is half the battle.
Yeah, you can do it that way, it is a good way to contribute. The PR's get manually merged by whoever thinks they should be merged.
Yeah, if you want to complete the commit and get it merged.
  • snowgoer540
  • Moderator
  • Moderator
06 Jul 2020 19:32 #173790 by snowgoer540
Do I have to do these as separate pull requests?
06 Jul 2020 19:34 #173791 by phillc54
No, keep it all under the one PR
  • snowgoer540
  • Moderator
  • Moderator
06 Jul 2020 19:50 #173792 by snowgoer540
perhaps a stupid question, but how do I add file changes to the PR I already started?
06 Jul 2020 19:55 #173793 by phillc54
If you commit work and then push to the branch you created if will keep if on the same PR
This is from your PR page: github.com/LinuxCNC/linuxcnc/pull/899
"Add more commits by pushing to the patch-1 branch on snowgoer540/linuxcnc"
Time to create page: 0.146 seconds
