Unknown m code used: M190
- CFE
- Thank you received: 35
21 Jul 2020 05:41 #175297
by CFE
Unknown m code used: M190 was created by CFE
Hi all,
We are battling a few issues after running an upgrade. We loaded an existing program which has cut no worries before the upgrade, but after the upgrade we get the error "Unknown m code used: M190" when we press the Run button. I repeat, this program ran without issues prior to the upgrade. What causes this ?
Cheers, Peter
Cheers, Peter
- phillc54
- Thank you received: 2100
21 Jul 2020 05:43 - 21 Jul 2020 05:43 #175298
by phillc54
Replied by phillc54 on topic Unknown m code used: M190
Sorry Peter, this one fell through the cracks...
In your .ini file find the line:and change it to:
You will need to restart LinuxCNC for it to take effect.
USER_M_PATH = ./USER_M_PATH = ./:./plasmacYou will need to restart LinuxCNC for it to take effect.
Last edit: 21 Jul 2020 05:43 by phillc54.
The following user(s) said Thank You: CFE
- CFE
21 Jul 2020 05:58 #175299
by CFE
Replied by CFE on topic Unknown m code used: M190
Hi Phil,
Thank you, that works !
Do you know how we can get spotting to work, it used to worked flawlessly before the upgrade, but not anymore. Leaves us baffled. Sorry to be a pain.
Cheers, Peter
Cheers, Peter
- phillc54
21 Jul 2020 06:06 #175300
by phillc54
If you run LinuxCNC from a terminal do you get any errors on starting?
Can you explain what is happening?
- CFE
21 Jul 2020 06:33 #175302
by CFE
Hi Phil,
It turns out that we needed to add a $2 after each M5 (for spotting). Funny that the same programs without that addition worked fine before the upgrade.
Thanks again for your help, much appreciated !
Cheers, Peter
Cheers, Peter
- phillc54
21 Jul 2020 06:39 #175303
by phillc54
Ahh, the spindle handling was recently changed in LinuxCNC itself. Now you need to use specific spindle numbers. It is a change for the better and a bit safer I feel.
Hi Phil,
Cheers, Peter
- CFE
21 Jul 2020 06:47 #175305
by CFE
It's true that it's better and safer, just a bit of a bugger we were not aware of it. And we have to modify the post processor to suit the change. And it means we have to edit all our existing programs that need this change. That might give the boys in the workshop a few headaches in the near future. Oops.
- phillc54
21 Jul 2020 06:53 #175306
by phillc54
There was a bit of discussion about it on the developers mailing list. It is probably worthwhile subscribing to it and then you can keep an eye on any changes to see if the will affect you.
sourceforge.net/projects/emc/lists/emc-developers
All Plasmac changes are announced on the forum as well so you should subscribe to that as well.
forum.linuxcnc.org/plasmac/37233-plasmac-updates#143119
Time to create page: 0.124 seconds
