Using Spotting with Sheetcam
- Clive S
- Thank you received: 486
21 Jul 2020 18:39 #175358
by Clive S
Using Spotting with Sheetcam was created by Clive S
I am going to try spotting some hole with sheetcan and PlasmaC.
In sheetcam I made a tool number 2 and ran the post then in the gcode it looks OK with the parameters the same as in the manual.
I think I may have read somewhere that you need to have the tool number in the linuxcnc tool table is that correct?
- Thank you received: 4154
21 Jul 2020 20:28 #175359
No thats for scribing. Just make a tool in Sheetcam called CENTRE SPOT and do a drilling operation with it.
Our grammatically challenged members not familiar with the Queen's English may use the more vulgar term CENTER SPOT
Replied by rodw on topic Using Spotting with Sheetcam
- Clive S
21 Jul 2020 21:36 #175361
by Clive S
Thanks Rod, This is the gcode just for a test . The test_1 is with the rotary tool and test_2 is when renamed the tool to centre spot.
Would you mind confirming if " test_2 is correct "
Replied by Clive S on topic Using Spotting with Sheetcam
Our grammatically challenged members not familiar with the Queen's English may use the more vulgar term CENTER SPOT![]()
- phillc54
- Thank you received: 2100
21 Jul 2020 23:05 #175363
by phillc54
Replied by phillc54 on topic Using Spotting with Sheetcam
If using the PlasmaC.scpost then there two methods of spotting:
1. You can use the CENTRE SPOT (CENTER SPOT) tool - you need to ensure that you made the leadin for a circle start at the centre as the spot is made at the start of the leadin.
2. You can use a drill operation using any tool.
The code looks OK assuming the spots are in the correct place.
- Clive S
22 Jul 2020 10:08 #175377
by Clive S
With the code above the torch does not fire. What am I missing?
Looking in the Lcnc tool table I see only 2 tools 0 and 1
- snowgoer540
- Thank you received: 907
22 Jul 2020 10:12 #175378
by snowgoer540
Did you enable the multiple tools in the <machine_name>_connections.hal?
Changeto
Yes, the offsets for the scribe tool are handled in the linuxcnc tool table. You can change it by editing the tool.tbl file in the <machine_name> folder.
Replied by snowgoer540 on topic Using Spotting with Sheetcam
Change
setp plasmac.multi-tool 0setp plasmac.multi-tool 1Yes, the offsets for the scribe tool are handled in the linuxcnc tool table. You can change it by editing the tool.tbl file in the <machine_name> folder.
- Clive S
22 Jul 2020 10:13 - 22 Jul 2020 10:16 #175379
by Clive S
Yes I have setp plasmac.multi-tool 1
Edit I looked in the tool table there is only 2 tools But I can't edit it as it is a sim link
Changetosetp plasmac.multi-tool 0setp plasmac.multi-tool 1
Last edit: 22 Jul 2020 10:16 by Clive S.
- phillc54
22 Jul 2020 10:13 #175380
by phillc54
Do you have multi tool enabled in your <machine_name>_connections.hal
LinuxCNC tool #0 is the torch and toll #1 is the scribe (if you have one) Spotting uses tool #0
- snowgoer540
22 Jul 2020 10:18 #175381
by snowgoer540
You shouldnt have to anyways, I apologize, I read scribe (theres still coffee to be drank in the pot), for spotting as Phill said, it uses the same offset as the torch.
- phillc54
22 Jul 2020 10:19 #175382
by phillc54
Have you set the threshold volts and delay time in the config panel.
Time to create page: 0.092 seconds
