PlasmaC not updating
26 Jul 2020 15:18 - 26 Jul 2020 18:30 #175910 by Clive S
PlasmaC not updating was created by Clive S
I am having a problem updating the config the one I am trying to update is on linux 2.8 under the config it is showing around V0.124
I have run sudo apt-get update and sudo dist-upgrade without success. I have also tried using through the configurator and clicking on upgrade that tells me it is up to date but it should be showing about V 0.146.
Is there a problem with the linux bot ?
Last edit: 26 Jul 2020 18:30 by Clive S.
27 Jul 2020 00:59 #175998 by phillc54
Replied by phillc54 on topic PlasmaC not updating
The Buildbot ran out of hard drive space and was fixed yesterday, it looks up to date at the moment.
27 Jul 2020 07:54 #176015 by Clive S
Replied by Clive S on topic PlasmaC not updating
Is the version number shown anywhere other than on the config screen. Such as in one of the files
Ie. so that I can see it if there is not a mesa card fitted. :)
27 Jul 2020 07:56 #176016 by phillc54
From a terminal enter "man plasmac" it is also in the plasmac_config.py file around a dozen or so lines from the bottom
27 Jul 2020 08:02 #176017 by Clive S
Thanks it does not look like its up to date here yet.
27 Jul 2020 08:05 #176019 by phillc54
That looks like your sources file is incorrect or you have connection problems.
27 Jul 2020 08:31 - 27 Jul 2020 08:32 #176021 by Clive S
I have just run it again using the terminal with its saved commands. It ran fine and went through and completed without errors.
I have done this many time before so happy with the commands.
But looking in the plasmac_config.py it still shows . self.plasmacVersion = 'PlasmaC v0.126'
But I don't have a card connected so can't fire up plasmac
Edit: I will go and do it on my machine in the garage
Last edit: 27 Jul 2020 08:32 by Clive S.
27 Jul 2020 08:35 #176022 by phillc54
Try running one of the sim configs from the config picker.
27 Jul 2020 08:39 #176023 by Clive S
Good idea. I have just done that. It shows v0.126 .So perhaps the bot has not caught up yet
27 Jul 2020 08:43 - 27 Jul 2020 08:43 #176024 by phillc54
I updated my local version from the buildbot this morning and it shows v0.146
Last edit: 27 Jul 2020 08:43 by phillc54. Reason: typo
Time to create page: 0.650 seconds
