Mesa Thcad-10 as the THC?
- luftlupus
- Thank you received: 16
11 Aug 2020 09:05 #177878
by luftlupus
Mesa Thcad-10 as the THC? was created by luftlupus
Probably a dumb question i have my plasma table firing and cutting on mode 1 at this moment in plasmac, reading voltage and all that.
Running mesa 7i76/6i25 THCAD-10 to read voltage. The question is can you use the THCAD-10 readout to control the Z height on the torch if i switched over to mode 2 in plasmac? or do i need an external THC? Cheers.
- phillc54
- Thank you received: 2100
11 Aug 2020 09:08 #177879
by phillc54
Replied by phillc54 on topic Mesa Thcad-10 as the THC?
If you are in mode 1 then the THCAD voltage is already used to control the torch height.
Mode 2 is for external THC controllers.
- luftlupus
11 Aug 2020 09:29 #177880
by luftlupus
Replied by luftlupus on topic Mesa Thcad-10 as the THC?
ok so i might have missed a setting of some sort as the z does not adjust while cutting.
- phillc54
11 Aug 2020 09:32 #177881
by phillc54
Do you have THC enabled in the Run Panel?
You should also have Auto Volts checked unless the Cut Voltage is definitely correct for your materials.
The following user(s) said Thank You: luftlupus
- luftlupus
11 Aug 2020 09:38 #177882
by luftlupus
yer i knew there would be something i have just completely missed, i will run the machine tomorrow and enable these settings, cheers mate.
- taloot
- Thank you received: 89
11 Aug 2020 17:10 #177910
by taloot
Externel THC is old and not performe good also expansive ( proma THC for example)
THCAD is better becouse u have full control over THC voltage from GUI. also performance much better
Replied by taloot on topic Mesa Thcad-10 as the THC?
- Thank you received: 7501
11 Aug 2020 20:02 - 11 Aug 2020 20:03 #177937
From extensive experience :
--Proma Elektronika THC150
-cheap at 200$
-good performance when set properly
-can not be destroyed even on purpose
-easy to install and set up
-slower than THCAD
-combined with thc_toma config works perfectly even on industrial retrofits, never fails
--Mesa THCAD 5/10/300
-extremely cheap
-extremely good performance
-fully integrated and automated in LinuxCNC
-easy to install and set up, but a bit harder than Proma
-much faster than Proma
-combined with PlasmaC config it can put to shame much, much more expensive industrial machines !!!
Replied by tommylight on topic Mesa Thcad-10 as the THC?
-Externel THC is old and not performe good also expansive ( proma THC for example)
-cheap at 200$
-slower than THCAD
-extremely cheap
Last edit: 11 Aug 2020 20:03 by tommylight. Reason: More info
The following user(s) said Thank You: phillc54, taloot, luftlupus
- luftlupus
13 Aug 2020 07:36 - 13 Aug 2020 07:44 #178079
by luftlupus
So i did some test cuts today and checked that thc was enabled as such which it was. I had just been using the extras tab to cut some circles at the moment, but still noticed that there was no z movement when in operation? does there need to be some kind of command in the gcode to enable thc during the cut? Cheers for any advice
Last edit: 13 Aug 2020 07:44 by luftlupus. Reason: photos
13 Aug 2020 07:41 #178080
Attach screenshots of the "run" and "config" panel please.
Does the voltage on screen fluctuate during cutting ?
- luftlupus
13 Aug 2020 07:45 - 13 Aug 2020 07:46 #178081
by luftlupus
added to previous post. Also i do see slight fluctuation yes depending on height from metal
Last edit: 13 Aug 2020 07:46 by luftlupus. Reason: info
Time to create page: 0.265 seconds
