THC Controller Polabs.com - PlasmaSensOut on LinuxCNC v2.8 connection
- hermann1976
- Thank you received: 17
16 Aug 2020 11:41 #178394
by hermann1976
Yes, the THC is working correctly.
When i disable the THC then the movement form the Z Axis does not work, even if a thc controller request is pending.
Everthing OK.
Replied by hermann1976 on topic THC Controller Polabs.com - PlasmaSensOut on LinuxCNC v2.8 connection
phillc54 wrote: Is your THC actually working correctly apart from the THC Active LED.
Everthing OK.
- phillc54
- Thank you received: 2100
16 Aug 2020 11:56 #178395
by phillc54
Replied by phillc54 on topic THC Controller Polabs.com - PlasmaSensOut on LinuxCNC v2.8 connection
OK, thanks.
I think we have to pick one of two options.
1. Hide the THC Active Led when in mode 2.
2. Turn on THC Active when THC is enabled and Arc OK is sensed. This is note quite true as it doesn't take into account any delay from the Arc OK signal until THC begins working. I assume these external THC units do have a delay.
- Thank you received: 7501
16 Aug 2020 12:22 #178397
Replied by tommylight on topic THC Controller Polabs.com - PlasmaSensOut on LinuxCNC v2.8 connection
IRC, Proma had a 100mS delay for sampling the voltage and a short delay for the time it takes the relay to switch over.I assume these external THC units do have a delay.
- phillc54
16 Aug 2020 12:26 #178398
by phillc54
Thanks Tom, a short delay like that kinda makes option 2 look not too bad.
16 Aug 2020 12:33 #178400
You are welcomed, always.
Am in a hectic state getting the big machine ready for transport and wiring a 120A plasma source to it with THCAD and everything, it has to be ready for tomorrow.
- phillc54
16 Aug 2020 13:08 #178402
by phillc54
Yeah, it always seems to be a rush at the end. Good luck.You are welcomed, always.
- phillc54
17 Aug 2020 03:41 #178456
by phillc54
I pushed the changes for the mode 2 THC Active Led
Time to create page: 0.840 seconds
